Unscrew 14 screws and remove the back frame.
Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator.
Loosen kinds of stickers fastening card reader assembly and battery.
Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly.
crwdns2935229:020crwdne2935229:0
crwdns2947412:09crwdne2947412:0
Hola, donde se puede comprar el reemplazo para el slot Sim-card del Moto G 2014 segunda generación?
Where can I get the replacement battery?
Ebay, Aliexpress, Amazon, etc.
Example : http://www.amazon.com/MOTOROLA-2070mAh-L...
Just look at the reference on your removed battery, and order the same.
Xavier -
Battery Problem battery fast charge & fast low
What is the Mobile
It is a moto g 2014
Cant believe how i was peeling at the orange stuff on the battery, shud have found this guide sooner.
Where can I buy the new sim card holder please?
The 2014 LTE model XT1072 has a different, two wire (red and black) battery connector (battery model ‘FT40’). It can be replaced by simply removing the copper foil, no need to remove the card reader first.
