Motorola Moto G 1st Generation Battery Replacement
  1. Motorola Moto G 1st Generation Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G 1st Generation Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
    • Remove any installed SIM card and memory microSD cards.
    • Push the SIM card into the phone, and the spring eject mechanism should release the card.
    • The microSD memory card(s) may not have an eject mechanism. If so, they must be removed carefully by pushing on the raised edge/bump that is built onto the card. Use your fingernail or a plastic or rubber tool, but not one that will scratch and damage the delicate card.
    • Patience must be taken to prevent irreversible damage and loss of data on the card.
  2. Motorola Moto G 1st Generation Battery Replacement, Removing the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Battery Replacement, Battery Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Battery Replacement, Battery Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Battery Replacement, Disconnecting the Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Battery Replacement, Disconnecting the Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the connection between the Battery and the Mother Board by using the Pry tool.
  5. Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the battery already disconnected,work around its edge with the pry tool to remove it from the assembly.
    • The battery is attached with a sticker, so it may take some work to pry up. Just work at it slowly and carefully until you get it.
crwdns2935229:05crwdne2935229:0
Radostin Lobodov
crwdns2935283:010/16/14crwdne2935283:0
2,946 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G7
Hello!
I have just completed this operation. I would like you to know that my Moto G 1st Generation needed a T4 Torx screwdriver.
Other than that, everything went fine!
Best Wishes,
Bubba G
Bubba G - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,448
