Motorola Moto E4 Charging Port Replacement
  1. Motorola Moto E4 Charging Port Replacement, Remove the rear cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Charging Port Replacement, Remove the rear cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Charging Port Replacement, Charging Port: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 4mm screws from the bottom plastic cover with a Phillips driver bit.
  3. Motorola Moto E4 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the plastic cover from the phone using an iFixit opening tool.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the two ribbon cable connectors from the top of the board using an iFixit opening tool.
    • Unplug the antenna cable connector from the board using an iFixit opening tool.
  5. Motorola Moto E4 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto E4 Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Halberd Spudger
    $2.99
  6. Motorola Moto E4 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm silver screws holding down the charging port board with Phillips bit.
  7. Motorola Moto E4 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E4 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the iFixit opening tool underneath the board in between the micro USB port and the microphone.
    • Push forward and lift gently until the board lifts up.
    • Remove the charging port board from the device.
    This is great info, but one thing is missing. Where do I get a new “charging port board” to replace the bad one?
    EDIT: OK. Found what I think is the correct part, but it would be great to be able to order it from you along with the tools not just the tools.
    russ.parker - crwdns2934203:0crwdne2934203:0
crwdns2935229:012crwdne2935229:0
Nate Tjepkema
crwdns2935283:001/24/19crwdne2935283:0
1,275 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G4, White Winter 2019 crwdns2935289:0Cal Poly, Team S2-G4, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S2G4
crwdns2935297:022crwdne2935297:0
crwdns2947412:08crwdne2947412:0
These directions don't seem very clear. In some pictures you have the parts in question circled. Why is this not done in every picture? Also, where you say to remove some parts, you're just holding tools to the places where they are. It would be more helpful if you included pictures where the part you're talking about is clearly removed.
It looks like only one person that has read these directions has actually completed the task using them. I'm not bad at this type of thing at all, but I feel that if I attempted to replace the charging port on my e4 using this guide there's a good chance I'd end up breaking it. And I love that phone!
When my charging port broke, I ended up financing a new phone from my carrier for three times what I paid for my e4, and the new phone sucks in comparison with it.
Thank you for thinking of people that have this dilemma and want to handle it themselves, but could you make your directions more specific?
Laura Patricia - crwdns2934203:0crwdne2934203:0
You should probably tell people to remove the ribbon connectors so they don’t break them trying to remove the charging board…
Other than that good guide.
Kyle Desrosiers - crwdns2934203:0crwdne2934203:0
Fails to include removing the vibration motor from the original board, a necessary (if easily worked out) step. It’s also kind of a useless guide given that the parts required are very difficult to find the correct version of, not helped by iFixit not stocking any despite it being a very commonly needed part.
(why motorola felt the need to make at least a dozen different versions of the super-tiny PCB that contains the common-failure point USB port I have *no* idea.)
Greg Burger - crwdns2934203:0crwdne2934203:0
To the 3 comments above .
Get a life ! ever heard of common sense ?
Not even a thank you to the author. Sad !
To the author well done and thank you. :)
FRED TILLEY - crwdns2934203:0crwdne2934203:0
Great article. Thanks. A couple of notes where my phone differed. My phone is a Motorola E4 (XT1761):
1 - one of the screws in step 2 had a sticker over it; presumably to void warranty if you remove it. I just scraped it away
2 - The aerial was on the other side from the picture.
3 - The vibrator was part of the unit; not a separate bit as in the instructions so didn’t need removal.
Christopher Marshall - crwdns2934203:0crwdne2934203:0
Has anyone found the needed part?
For the XT1768 the part number is 84016691001 REV A
but I can’t find it anywhere.
Thanks-
Colby Kelly - crwdns2934203:0crwdne2934203:0
This article was great! However, there are a few notes I’d like to leave for people also changing their charging port.
1. The two silver screws on step 6 were really stubborn for me and hard to get out, it may require some force.
2. Some third-party charging ports do not come with a microphone (a little black square) you may need to transfer it from your old one to the new one.
3. Also for the vibrator on step 5, you may need to place it on the new board (there should be a connector that you can remove)
Rob - crwdns2934203:0crwdne2934203:0
I repair my charging pin 50 times but it's not work what would I do
Rimsha khan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,317
