Motorola Moto E Battery Replacement
  1. Motorola Moto E  Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto E  Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device before beginning the battery replacement.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E  Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E  Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E  Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E  Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E  Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift gently on the battery using the metal spudger tool.
    • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
crwdns2935229:036crwdne2935229:0
Alex Craig
crwdns2935283:003/11/15crwdne2935283:0
2 611 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 5-7, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 5-7, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S5G7
crwdns2947412:07crwdne2947412:0
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - crwdns2934203:0crwdne2934203:0
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - crwdns2934203:0crwdne2934203:0
This worked very well for me, many thanks!
Tony Franks - crwdns2934203:0crwdne2934203:0
which battery type or brand should we purchase????????
hridaya123.praja - crwdns2934203:0crwdne2934203:0
Works perfectly! Wonderful illustrations & text guide. (As long as you use the recommended tools).
Gerald Griffin - crwdns2934203:0crwdne2934203:0
Be aware — these instructions don’t apply to the 2nd generation Moto E. I discovered this when I couldn’t get the back cover off. It’s friction-fitted on the Gen 1, apparently, but glued on with the Gen 2. The rest of the procedure is also far more complex for the Gen 2.
Paul Abrahams - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 117
crwdns2942667:0crwdne2942667:0 77,588
