The O-Ring is fragile. Take care not to let it break when dealing with it.
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
Gently slide the blue opening pick between the rear cover and the metal casing.
Work your way entirely around the rear cover.
Once the adhesive has been successfully loosened, gently pull the rear cover off.
To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
Pinch the green rubber O-Ring and slide it off of the watch.
Where can you get your hands on a replacement o'ring?!
I broke my o-ring. Any ideas where I could get a raplacement?
i think you should not take the o ring. i was replaceing the battery without take the O ring
