The entirety of the Moto 360 is very fragile. Take extreme caution when using tools.
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
Gently slide the blue opening pick between the rear cover and the metal casing.
Work your way entirely around the rear cover.
Once the adhesive has been successfully loosened, gently pull the rear cover off.
To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
Pinch the green rubber O-Ring and slide it off of the watch.
Set the Moto 360 face up on a flat surface.
Place the iOpener on the face of the device screen.
Gently slide the opening pick between the screen and the metal casing.
Work your way around the face of the screen, loosening the adhesive.
Detach the copper ribbon connecting the motherboard to the display.
For reassembly, attach copper ribbon where it is marked.
Slide the display out of the metal casing.
crwdns2935229:015crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Good morning,
It is possible to replace the display unit for the Moto 360 2nd with 1.56" display?
Thanks in advance and best regards,
Stephan
Stephan Müller - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Were could i buy a new lcd screen for the moto 360 1st gen??
Sebastian Galvan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
hey mate you can buy one from aliexpress aliexpress moto 360 screen see link below
Faddy Oraha - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I get a LCD display for a Moto 360 2 gen 42mm. Thanks hope you can help
Glenn Patoska - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bonjour,
Où est-il possible de trouver des pièces détachées ?
Le fond du boitier.
Merci de votre réponse.
DOGUE - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
