Motorola Moto 360 2nd Gen LCD Display Replacement
  1. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the watch band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the watch band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the watch band: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or the tip of a spudger to compress the pin securing the watch band.
    • With the pin compressed, remove the watch band.
  2. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the trim ring: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the trim ring: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the trim ring: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool to into the small notch next to the microphone hole.
    • Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
    • If the trim ring does not readily separate from the watch, heat it with an iOpener or hair dryer to soften the adhesive.
    • Remove the trim ring.
    I am salivating at the trim ring because I've needed one for about a year and a half ?
    Buff Boi - crwdns2934203:0crwdne2934203:0
  3. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button trim: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button trim: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to slowly pry the button trim ring straight up.
    • If you bend or rotate the trim ring while removing it, you may damage the small pins that secure it.
  4. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the button: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small pin spanner to unscrew the button.
    • If you don't have access to the proper spanner, you can use a pair of tweezers, a very small screwdriver, or a paperclip to unscrew the button assembly. Insert your chosen tool into one of the grooves around the button and push sideways.
    • There is blue thread locker on these threads, so light heat on the button may help to soften the thread locker.
    • Remove the button.
    • There is a small red o-ring that may fall off the button threads when the button is removed. Make sure not to lose the o-ring.
    Leave the ring from the previous step partially in and use it as a wrench on the actual nut.
    bennettr8 - crwdns2934203:0crwdne2934203:0
    It's a great idea in theory, but how do you grip the ring to turn it?
    Ryan Erickson -
    You are my hero! Heating and trying to turn it using tweezers didn't work, but this did.
    Brent Womble - crwdns2934203:0crwdne2934203:0
    Literally jabbed myself with tweezers trying the op way. Thank you for this. I’d rather keep the rest of my blood in my body.
    Giovanni - crwdns2934203:0crwdne2934203:0
    Brilliant suggestion many thanks.
    Barry van Uden - crwdns2934203:0crwdne2934203:0
    How do you get the ring to do that? Having a hard time with this step 😅
    Andres Duran Kenny Espinosa - crwdns2934203:0crwdne2934203:0
    Note that the recommended Spanner Set on this page is too big for this job, None of the "pins" fit.
    Ik heb werkelijk geen idee hoe ik die pijn los krijg. Kan dit vergroot worden getoond op de foto? Eventueel met meer uitleg (welke kant draai je op, wat draai je precies). Verder super blij met deze uitleg, maar ik loop dus helaas vast.
    Roger Milder - crwdns2934203:0crwdne2934203:0
  5. Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the inner assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Remove the inner assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
  6. Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
    • It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
  7. Motorola Moto 360 2nd Gen LCD Display Replacement, Open the inner assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Open the inner assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement, Open the inner assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
    • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
  8. Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
    What if the rubber strip tears? What is it’s purpose?
    Neil Myrick - crwdns2934203:0crwdne2934203:0
    This and the following step are unnecessary.
    Drive Foxes - crwdns2934203:0crwdne2934203:0
    Adding another comment not to do this step or the subsequent ones for removing the display connector. They are unnecessary, and the parts are fragile. Otherwise an excellent guide.
    Andrew Champion - crwdns2934203:0crwdne2934203:0
  9. Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the locking flap on the display ZIF connector.
    Reattaching this is a nightmare. I never found any locking flap. The cable pulled out, but getting it to stay when I put it back together was tough. Not sure how long it will hold while in actual use.
    I cannot reattach my display cable and my watch is now useless. Really angry as this step IS NOT NECESSARY. You can easily change the battery without doing this. DON’T DO THIS.
    Richard Storer - crwdns2934203:0crwdne2934203:0
    Agreed - this should be removed from instructions. It is just destructive. Wish I had seen these comments before I did this.
    Robert Long - crwdns2934203:0crwdne2934203:0
    Agree with all the above. AND I am replacing the display so I MUST attach the new cable and cannot for the life of me figure out this ZIFF connector. It is a mystery.
    Gary Blasberg - crwdns2934203:0crwdne2934203:0
  10. Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto 360 2nd Gen LCD Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display cable straight out of its connector on the motherboard.
  11. Motorola Moto 360 2nd Gen LCD Display Replacement, Removing LCD: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the screen frame on a solid surface on its back, put even pressure down across the screen to put it out of the back of the frame, warming it will help loosen the adhesive.
    Do not follow this it makes you break the piece that holds the button in. I broke my watch following this. I figure it out afterward but too late, the button and its surrounding unscrews out.
    John DeLorenzo - crwdns2934203:0crwdne2934203:0
    Need a Moto 360 2nd gen 46 mm display LCD. If available please help me.
    Vinoth Kumar - crwdns2934203:0crwdne2934203:0
    I've edited it, hopefully will be accepted. You certainly don't stick a knife down the side to try to free it, you'll just break it. Even pressure on the glass side to push it through.
    Arkz - crwdns2934203:0crwdne2934203:0
Ivana Lum Wai
crwdns2935283:008/22/17crwdne2935283:0
263 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S6-G1, Remmell Fall 2017 crwdns2935289:0USF Tampa, Team S6-G1, Remmell Fall 2017crwdne2935289:0
USFT-REMMELL-F17S6G1
crwdns2935297:019crwdne2935297:0
Where can I buy the screen for the 2-nd generation Moto360 watch ?
Kevin - crwdns2934203:0crwdne2934203:0
Its far easier to remove watch from body by unscrewing the crown, remove the bottom ring then heat the bezel a little so that you can turn the bezel about 10mm counter clockwise with a razor blade edge, then push the whole body of the watch through the metal casing and it should come out easily through the top of the watch in one piece making it easier to access the pcb without damaging anything
Bernard McGrath - crwdns2934203:0crwdne2934203:0
There is only one correct way to disassemble the watch. That is to unscrew the crown as mentioned in previous comment and another guide for 360 Gen 2.
This guide here should be either revised or taken down.
It leads to broken watch if you tried to follow. I was lucky to step out from step 5 and followed the other guide instead…
vincent0wang - crwdns2934203:0crwdne2934203:0
That last step will destroy the screen btw. Sticking a knife down the side to pry it out will just rip the backlight off the lcd. You put even pressure on the glass on the front to pop it out of the back, might take a while as it's stuck in. warming it will help.
crwdns2942667:0crwdne2942667:0 7,929
