Motorola Edge Plus 2020 Battery Replacement
  1. Motorola Edge Plus 2020 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iOpener or hair dryer to heat the perimeter of the back cover to loosen the adhesive beneath.
    • Insert the tip of an opening pick 2-3 mm into the seam between the back cover and chassis.
    • Slide the pick around the entire perimeter of the case to sever the adhesive, inserting additional opening picks periodically to prevent the back cover from resealing.
    • If the adhesive hardens as it cools, apply additional heat as needed.
    • Remove the back cover.
  2. Motorola Edge Plus 2020 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, discharge your phone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Remove the following T3 Torx screws:
    • Ten 6 mm silver screws
    • Six 5 mm black screws
  3. Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the daughterboard and motherboard covers.
    • Disconnect and remove the wireless charging coil.
  4. Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat edge of a spudger under the interconnect cable's motherboard press connector and lift it straight up to disconnect it.
    • Repeat for the interconnect cable's daughterboard connector.
    • Remove the internet cable.
  5. Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to lift and disconnect the battery press connector.
    • If you're completing a camera replacement guide, skip to the beginning of that procedure. It's not necessary to remove the battery.
  6. Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Plus 2020 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of high-concentration isopropyl alcohol beneath the battery.
    • Tilt the phone to allow the alcohol to reach all of the adhesive.
    • Alternatively, lightly heat the battery with an iOpener or hairdryer.
    • Insert a spudger beneath the battery and gently pry the battery up and out of the chassis.
    • Do not bend, warp, or puncture the battery.
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Stanley Trang
crwdns2935283:001/23/25crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-5, Virtue Spring 2025 crwdns2935289:0Western Carolina University, Team 1-5, Virtue Spring 2025crwdne2935289:0
WCU-VIRTUE-S25S1G5
crwdns2942667:0crwdne2942667:0 223
