Motorola E815 Keypad Replacement
Zoie E
crwdns2944107:0crwdnd2944107:0Zoie Ecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
crwdns2931287:010crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If the buttons on your Motorola E815 are unresponsive or do not seem as crisp as they used to be, you may need to replace your keypad. To accomplish this, you will
  • Dissemble the phone
  • Access the keypad for repair or replacement
crwdns2944105:0crwdne2944105:0
  1. Motorola E815 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Keypad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Keypad Replacement, Disassembling Motorola E815 Antenna: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Keypad Replacement, Keypad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Motorola E815 Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Motorola E815 Keypad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Motorola E815 Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Motorola E815 Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Motorola E815 Keypad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola E815 Keypad Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
Zoie E
crwdns2935283:001/12/11crwdne2935283:0
603 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-8, Forte Winter 2011 crwdns2935289:0Cal Poly, Team 14-8, Forte Winter 2011crwdne2935289:0
CPSU-FORTE-W11S14G8
We should have a motherboard replacement.
Santi12008 - crwdns2934203:0crwdne2934203:0
We need to fullify more this content.
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,136
