Use this guide to replace the motherboard in your Moto G6 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
While this guide may include images of the device with the battery removed, it is not necessary to remove the battery to replace the motherboard.
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the upper right edge of the phone.
Press the tool into the hole to eject the tray.
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
If you are having no luck getting the bottom to lift, even when it's almost too hot to touch, try starting on a side near the bottom. The adhesive for the bottom was twice as wide as on the sides and even giving up on the iOpener and using a heat gun I could not get the bottom to lift at all, so I moved to the bottom left side and started there.
YES. This is the way. Thank you!
mttwlk -
Thank you for this comment! Completely agree. I was having no luck starting with the bottom and things worked much better when starting on the side.
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Heat the right edge of the back of the phone to soften the adhesive underneath.
Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
Leave the pick under the top right corner of the glass to prevent the adhesive from re-adhering. Continue with a new pick.
Heat the top edge of the back of the phone to soften the rear glass adhesive.
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
Leave the pick under the top left corner of the glass to prevent the adhesive from re-adhering. Continue with a new pick.
Heat the left edge of the back of the phone to soften the adhesive underneath.
Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
There are two strips of adhesive on either side of the lower half of the phone that must be separated to remove the rear glass panel.
You will need to release these adhesive strips without damaging the fingerprint sensor cable located in the center of the phone.
Insert the flat end of a spudger into the lower half of the right side of the phone about 2 cm and slide it down the right edge to release the right strip of adhesive.
Insert a spudger into the lower half of the left side of the phone about 2 cm and slide it down the left edge to release the left strip of adhesive.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice any remaining adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Open the rear glass.
Use a Phillips screwdriver to remove the two screws securing the fingerprint sensor cable retention bracket:
One silver 1.5 mm screw
One gold 3.5 mm screw
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the fingerprint sensor cable retention bracket.
Use the pointed edge of a spudger to disconnect the fingerprint sensor cable.
Remove the rear glass panel.
Use a Phillips screwdriver to remove the fifteen gold 3.5 mm screws securing the plastic midframe.
Ein Stückchen Klebeband hilft beim Herausziehen der Schrauben. Auch Krümel vom Kleber können einfach mit Klebestreifen aufgetupft werden.
Insert a spudger into the notch on the upper right edge of the midframe.
Pry the midframe up to release the clips securing it to the device's aluminum frame.
Remove the plastic midframe.
Use a spudger to pry up and disconnect the battery cable.
Use a pair of tweezers to carefully remove the tape covering the camera module connector.
Use the flat end of a spudger to pry up the camera module connector and disconnect it.
Remove the camera module.
Insert the pointed end of a spudger underneath the bottom left corner of the earpiece speaker and pry it up.
Remove the earpiece speaker.
Use a spudger to pry up and disconnect the daughterboard flex cable from the motherboard.
Use a spudger to pry up and disconnect the display flex cable.
Use a pair of tweezers to remove the piece of tape covering the side button flex cable connector.
Retain this piece of tape for reassembly.
Use the pointed end of a spudger to flip up the locking flap on the side button ZIF connector.
Use a pair of tweezers to slide the side button cable out of its socket.
Use the pointed end of a spudger to pry up and disconnect the black antenna cable.
Use the pointed end of a spudger to pry up and disconnect the blue antenna cable.
Use a Phillips screwdriver to remove the two silver 2 mm screws securing the motherboard.
Use the pointed edge of a spudger to pry up the top right corner of the motherboard.
Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto G6 Play Answers Community for help.
crwdns2935229:05crwdne2935229:0
Well, Hi guys i have a situation here that i changed my screen from my moto g6 play. But at the moment that i want to use it again, bluetooth, Wi-Fi, Speakers and mic doesn’t work. Any solution about this?
Hi guys my problem with my Motorola g6 play is display light it is verry low I tried to sett it but still no light.
