Use this guide to replace the earpiece speaker on your Moto G6 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
While this guide may include images of the device with the battery and rear-facing camera removed, it is not necessary to remove these components to replace the earpiece speaker.
            If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
            Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
            Apply a suction cup to the bottom edge of the rear glass.
            Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
            If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
            Insert an opening pick into the gap you created under the rear glass.
            Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
            Heat the right edge of the back of the phone to soften the adhesive underneath.
            Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
            Leave the pick under the top right corner of the glass to prevent the adhesive from re-adhering. Continue with a new pick.
            Heat the top edge of the back of the phone to soften the rear glass adhesive.
            Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
            Leave the pick under the top left corner of the glass to prevent the adhesive from re-adhering. Continue with a new pick.
            Heat the left edge of the back of the phone to soften the adhesive underneath.
            Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
            There are two strips of adhesive on either side of the lower half of the phone that must be separated to remove the rear glass panel.
            You will need to release these adhesive strips without damaging the fingerprint sensor cable located in the center of the phone.
            Insert the flat end of a spudger into the lower half of the right side of the phone about 2 cm and slide it down the right edge to release the right strip of adhesive.
            Insert a spudger into the lower half of the left side of the phone about 2 cm and slide it down the left edge to release the left strip of adhesive.
   crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99-
            If the glass remains stuck, re-heat and slice any remaining adhesive repeatedly as needed.
            Lift the rear glass carefully, making sure it's fully separated from any adhesive.
            Open the rear glass.
            Use a Phillips screwdriver to remove the two screws securing the fingerprint sensor cable retention bracket:
            One silver 1.5 mm screw
            One gold 3.5 mm screw
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use a pair of tweezers to remove the fingerprint sensor cable retention bracket.
            Use the pointed edge of a spudger to disconnect the fingerprint sensor cable.
            Remove the rear glass panel.
            Use a Phillips screwdriver to remove the fifteen gold 3.5 mm screws securing the plastic midframe.
            Insert a spudger into the notch on the upper right edge of the midframe.
            Pry the midframe up to release the clips securing it to the device's aluminum frame.
            Remove the plastic midframe.
            Use a spudger to pry up and disconnect the battery cable.
            Insert the pointed end of a spudger underneath the bottom left corner of the earpiece speaker and pry it up.
            Remove the earpiece speaker.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto G6 Play Answers Community for help.
