Minolta Dimage Xt Casing Replacement
  1. Minolta Dimage Xt Casing Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Casing Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Casing Replacement, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    #000 bit seems to work better. There are seven screws in total (2 on either end and 3 on bottom).
    Doug Ewing - crwdns2934203:0crwdne2934203:0
  2. Minolta Dimage Xt Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Casing Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
    Lens cover can be accessed without removing rear housing. I was able to lift off the front to access the lens cover mechanism while leaving the rear in place.
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
crwdns2935283:003/11/13crwdne2935283:0
56 crwdns2915208:0crwdne2915208:0
Clemson, Team 12-4, Benson Spring 2013 crwdns2935289:0Clemson, Team 12-4, Benson Spring 2013crwdne2935289:0
CLEM-BENSON-S13S12G4
How to reattach the ribbon????
rosybrier - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 515
