Mini Fridge Hinges Replacement
  1. Mini Fridge Hinges Replacement, Hinges: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plug from the outlet. Be sure to grab from the head of the cord.
  2. Mini Fridge Hinges Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all food items and shelves from the fridge.
    • Place removed contents to the side and if needed place food items in another fridge temporarily.
  3. Mini Fridge Hinges Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mini Fridge Hinges Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover to the top hinge to access the hinge and screws. If you are unable to remove the cover with your hands, use a flathead screwdriver to pry it off.
    • Remove the three 20 mm Phillips #1 screws from beneath the cover.
  4. Mini Fridge Hinges Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Fridge Hinges Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Fridge Hinges Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the top hinge, lift the door off of the bottom hinge.
    • Place the door and removed top hinge securely to the side.
  5. Mini Fridge Hinges Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mini Fridge Hinges Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the fridge onto its side.
    • Do not turn the fridge upside down to protect the internal components of the fridge.
    • Remove the two 19 mm Phillips #1 screws and the bottom hinge.
    After laying it on it’s side does the mini-fridge need to stand upright for a certain period of time before plugging it into power. If so, that would be really good info to add here.
    sbacklun - crwdns2934203:0crwdne2934203:0
  6. Mini Fridge Hinges Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the bottom replacement hinge and the two 19 mm Phillips #1 screws.
    • Turn the fridge right side up after the bottom hinge is replaced.
  7. Mini Fridge Hinges Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the door on the bottom hinge, aligning the hole with the hinge.
    • Install the new top hinge and the three 20 mm Philips #1 screws. Ensure the orientation of the hinge lines up with the door.
    • Tighten as needed until the fridge door opens and closes normally and is not uneven.
    • Replace the top cover and the shelving inside the fridge.
This is a relatively easy fix and is easily repeatable. The replacement parts are inexpensive. We hope this guide extends the life of a mini fridge and expands your understanding of the topic.
Adam Millen
crwdns2935283:001/29/20crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S11-G5, Salas Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S11-G5, Salas Spring 2020crwdne2935289:0
ERAU-SALAS-S20S11G5
My fridge is not working Death ho gaya h bikul kuch bbi n chal rha h
Prince Singh - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 4,422
