Milwaukee Sawzall 6520-21 Motor Replacement
  1. Milwaukee Sawzall 6520-21 Motor Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement, Power Cord: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement, Power Cord: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the Sawzall and Orient the right half-handle to face upwards.
    • With a T20 Torx screwdriver, remove the following screws:
    • 7-18 x 1.125-inch Slt. Plastite T-20
    • 8-16 x .625-inch Slt. Plastite T-20
    • The right-half handle does not contain any wires on the underside.
    • Lift the handle off.
  2. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two rubber rings around the divots hold the cushion grip to the handle.
    • Lift off the cushion grip.
  3. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw above the trigger.
    • 8-16 x .625-inch
    • The trigger wires threaded through the handle are not fastened. They do not require any tool to pull out.
  4. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take a 1.5mm flathead screwdriver and insert it into the pin lock above each of the wires:
    • Black wire: Insert it on the left side of the pin. Pull the wire while gently rotating it clockwise
    • Black wire: Insert it on the bottom side of the pin and gently rotate it counterclockwise
    • White wire: Insert it on the right of the pin and gently rotate it counterclockwise
  5. Milwaukee Sawzall 6520-21 Motor Replacement, Trigger: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement, Trigger: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the yellow electrical wire.
  6. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The left half handle and motor housing can separate without difficulty.
    • The trigger paired with the motor housing wire requires two removals.
    • Gently remove both white wires.
  7. Milwaukee Sawzall 6520-21 Motor Replacement, Motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement, Motor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement, Motor: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide the following from the motor housing:
    • Black chip.
    • Blue electrical wire.
    • Two, white electrical wires.
  8. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the shoe release lever in its unlocked position.
    • Remove the shoe assembly.
    • There is a pin that holds the shoe release lever
    • Detach the lever.
  9. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push or pull the shoe pin to remove it from the gear case insulator.
    • Remove the insulator.
    • This requires a lot of force to remove. It's recommended to have help from another person.
  10. Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Sawzall 6520-21 Motor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T20 Torx screwdriver to remove the following four screws from the gearcase:
    • K50 x 60 mm Washer Hd. PT Screw
    • Detach the motor housing from the gearcase.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Garret Haub
crwdns2935283:010/28/24crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
Cuesta, Team 10-1, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 10-1, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S10G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 52
