Microsoft Surface Pro X Battery Replacement
  1. Microsoft Surface Pro X Battery Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
    Where can one find these drives to replace the one that comes with it?
    daveniezby - crwdns2934203:0crwdne2934203:0
    I think I found mine on Amazon
    Tom Manson - crwdns2934203:0crwdne2934203:0
  2. Microsoft Surface Pro X Battery Replacement, Open the SSD and SIM card door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Open the SSD and SIM card door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X Battery Replacement, Remove the SSD and SIM card door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  4. Microsoft Surface Pro X Battery Replacement, Remove the SSD screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X Battery Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. Microsoft Surface Pro X Battery Replacement, Tape the screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Tape the screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Tape the screen: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  7. Microsoft Surface Pro X Battery Replacement, Apply a suction cup to the screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Apply a suction cup to the screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wear safety glasses during the screen removal procedure in case the glass shatters while you're working.
    • There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to work slowly and be extremely careful while slicing through the adhesive.
    • Place your tablet on your work surface so that the screen is facing up.
    • Apply a suction cup to the screen next to the right speaker grille.
  8. Microsoft Surface Pro X Battery Replacement, Secure the tablet: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your hand on the screen next to the suction cup to secure the Surface while you lift up the screen.
  9. Microsoft Surface Pro X Battery Replacement, Create a gap between the screen and frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Create a gap between the screen and frame: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Create a gap between the screen and frame: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert the opening pick more than 3 mm while cutting through the adhesive on the right, bottom, and left edge.
    • Lift up on the suction cup to create a gap between the screen and the frame.
    • The gap only needs to be wide enough to slide in an opening pick.
    • Insert an opening pick about 2 mm into the gap. Leave the opening pick in the gap to prevent it from resealing.
  10. Microsoft Surface Pro X Battery Replacement, Cut through the screen adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Cut through the screen adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick into the gap between the screen and the frame.
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  11. Microsoft Surface Pro X Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert the pick more than 3 mm while cutting through the screen adhesive on the bottom edge or you may damage delicate components on the screen.
    • Insert a third opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
  12. Microsoft Surface Pro X Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  13. Microsoft Surface Pro X Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  14. Microsoft Surface Pro X Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert the opening pick more than 10 mm while cutting through the adhesive on the top edge. Don't insert the pick more than 3 mm near the speaker grille.
    • Insert a fifth opening pick into the top left corner and slide it around the corner toward the top edge.
    • Slide the pick along the top edge of the Surface to cut through the screen adhesive.
  15. Microsoft Surface Pro X Battery Replacement, Open the Surface: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Open the Surface: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Open the Surface: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not remove the screen yet. It is still connected to the motherboard by the display cable. Keep the screen as close as possible to the Surface's frame to avoid straining the display cable.
    • Avoid hitting the battery with the screen during this procedure. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Lift up the top edge of the screen so that it is at a 30° angle with the frame.
    • If you encounter any resistance, stop and check that all the adhesive is separated. Use an opening pick to cut through any remaining adhesive.
    • Rotate the screen so that its bottom edge is in the middle of the frame. The screen should be perpendicular to the frame.
    • Rotate the screen 90° so that it is facing down. Place the screen on the frame.
  16. Microsoft Surface Pro X Battery Replacement, Remove the display cable shield: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the display cable shield: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the display cable shield: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a tine of a pair of pointed tweezers under the bottom right corner of the display cable shield (where the display cable is oriented down).
    • Lift up the corner to detach it from the screen.
  17. Microsoft Surface Pro X Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the bottom right corner.
  18. Microsoft Surface Pro X Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display cable shield from the screen.
    • If the display cable shield isn't completely detached from the screen, pry up additional areas around the edges of the shield.
  19. Microsoft Surface Pro X Battery Replacement, Disconnect the screen: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the screen: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger under the right side of the display cable press connector.
    • Lift up the right side of the press connector to detach it from the display cable socket on the screen.
  20. Microsoft Surface Pro X Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step on the left side of the display cable connector to fully disconnect it from the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Microsoft Surface Pro X Battery Replacement, Remove the screen: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen from the frame.
  22. Microsoft Surface Pro X Battery Replacement, Speaker grille information: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Speaker grille information: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The left and right speaker grilles may be attached to the Surface's frame or the screen.
    • If you are going to replace a speaker grille that is attached to the frame, follow these steps to remove it:
    • Use an opening pick to cut through the adhesive under the grille.
    • Remove the speaker grille.
    • Repeat for the other speaker grille.
  23. Microsoft Surface Pro X Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you are going to replace or transfer a speaker grille that is attached to the screen, follow these steps to remove it:
  24. Microsoft Surface Pro X Battery Replacement, Screen adhesive information: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Screen adhesive information: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Screen adhesive information: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are going to replace the screen adhesive, follow these steps:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the adhesive.
    • Use a cotton swab or the flat end of a spudger to scrape away the adhesive.
    • Use a lint-free cloth or coffee filter to wipe away any remaining adhesive.
    • Allow the surface to dry completely before applying replacement adhesive.
    • Apply new adhesive strips or pre-cut adhesive to the frame where the old screen adhesive was located.
  25. Microsoft Surface Pro X Battery Replacement, Remove the heat sink sticker: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the heat sink sticker: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you are going to reinstall this sticker during reassembly, try to keep it as intact as possible.
    • Lift up the edge of the heat sink sticker closest to the bottom edge of the Surface.
  26. Microsoft Surface Pro X Battery Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the center of the sticker.
  27. Microsoft Surface Pro X Battery Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up one side of the sticker attached to the heat sink.
    • Repeat for the other side. The sticker should now be fully detached.
    • Remove the sticker.
  28. Microsoft Surface Pro X Battery Replacement, Remove the screw stickers: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the screw stickers: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you are going to reinstall these stickers during reassembly, try to keep them as intact as possible. These stickers can tear easily during removal.
    • Use an opening tool to lift up the edge of one of the small black stickers covering the four screws in the center of the heat sink.
    • You only need to lift the edge enough to grip it with tweezers.
  29. Microsoft Surface Pro X Battery Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt tweezers to remove the sticker covering the heat sink screw.
    • Repeat this process for the other three stickers.
  30. Microsoft Surface Pro X Battery Replacement, Remove the heat sink screws: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 14 screws securing the heat sink:
    • Eight 2.2 mm T3 Torx screws
    • One 2.0 mm T3 Torx screw
    • One 3.2 mm T3 Torx screw
    • Four 2.5 mm T6 screws
  31. Microsoft Surface Pro X Battery Replacement, Remove the heat sink: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the heat sink: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The heat sink is adhered to the CPU with thermal paste.
    • Insert an opening pick about 2 mm under the heat sink at its bottom edge directly to the left of the display cable.
    • The opening pick should be between the heat sink and the frame surrounding the motherboard.
    • Slide the opening pick to the left toward the heat pipe to detach the heat sink from the CPU.
  32. Microsoft Surface Pro X Battery Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Swing the bottom edge of the heat sink up so that it is at about a 10° angle with the frame.
  33. Microsoft Surface Pro X Battery Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  34. Microsoft Surface Pro X Battery Replacement, Disconnect the right speaker: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the right speaker: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the right speaker's press connector from its socket.
  35. Microsoft Surface Pro X Battery Replacement, Detach the right speaker's cable: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Detach the right speaker's cable: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the right speaker's cable and detach it from the frame.
  36. Microsoft Surface Pro X Battery Replacement, Lift up the foam adhesive: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Lift up the foam adhesive: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift up the foam adhesive covering the right speaker's top right screw.
  37. Microsoft Surface Pro X Battery Replacement, Remove the right speaker screws: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws securing the right speaker:
    • One 2.2 mm T3 Torx screw
    • One 2.9 mm T6 Torx screw
  38. Microsoft Surface Pro X Battery Replacement, Remove the right speaker: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the right speaker: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the right speaker: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lift the cable side of the right speaker enough to grab it with your fingers.
    • Remove the right speaker from the frame.
  39. Microsoft Surface Pro X Battery Replacement, Remove the display cable shield: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the display cable shield: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the display cable shield: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • If you are going to reuse this shield, try to avoid excessively bending it during removal.
    • Note that the display cable is oriented down for this shield removal procedure.
    • Insert one tine of a pair of pointed tweezers into a divot on a tab in the top right corner of the display cable shield.
    • Lift up the corner to detach it from the frame.
  40. Microsoft Surface Pro X Battery Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one tine of a pair of pointed tweezers under the right side of the top edge of the shield to detach it from the frame.
    • Repeat for the left side of the top edge.
  41. Microsoft Surface Pro X Battery Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one tine of a pair of pointed tweezers under the right side of the top edge of the shield.
    • Lift up the top edge to further detach it from the frame.
  42. Microsoft Surface Pro X Battery Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide one tine of a pair of pointed tweezers under the top side of the right edge of the shield.
    • Lift up to detach the top section of the shield from the frame.
    • Repeat for the top side of the left edge.
  43. Microsoft Surface Pro X Battery Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one tine of a pair of pointed tweezers under the right edge of the shield near the top right corner.
    • Lift up to further detach the shield from the frame.
  44. Microsoft Surface Pro X Battery Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the center of the right edge of the shield.
  45. Microsoft Surface Pro X Battery Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one tine of a pair of pointed tweezers under the left edge of the shield near the top left corner.
  46. Microsoft Surface Pro X Battery Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the center of the left edge of the shield.
  47. Microsoft Surface Pro X Battery Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one tine of a pair of pointed tweezers under the right edge of the shield near the bottom right corner.
    • Lift up the right edge to detach the shield from the frame.
  48. Microsoft Surface Pro X Battery Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display cable shield.
    • If the shield isn't completely detached from the frame, pry up additional areas around the edges of the shield.
  49. Microsoft Surface Pro X Battery Replacement, Disconnect the display cable: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the display cable: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the display cable press connector from its socket.
  50. Microsoft Surface Pro X Battery Replacement, Remove the display cable: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display cable from the Surface.
  51. Microsoft Surface Pro X Battery Replacement, Disconnect the left speaker: crwdns2935265:051crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the left speaker: crwdns2935265:051crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the left speaker's press connector from its socket.
  52. Microsoft Surface Pro X Battery Replacement, Detach the left speaker's cable: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Detach the left speaker's cable: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the left speaker's cable and detach it from the frame.
  53. Microsoft Surface Pro X Battery Replacement, Lift up the foam adhesive: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Lift up the foam adhesive: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift up the foam adhesive covering the left speaker's top left screw.
  54. Microsoft Surface Pro X Battery Replacement, Remove the left speaker screws: crwdns2935265:054crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws securing the left speaker:
    • One 3.0 mm T3 Torx screw
  55. Microsoft Surface Pro X Battery Replacement, Remove the left speaker: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the left speaker: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the left speaker: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lift the cable side of the left speaker enough to grab it with your fingers.
    • Remove the left speaker from the frame.
  56. Microsoft Surface Pro X Battery Replacement, Lift the corner of the shield: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Lift the corner of the shield: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take care not to puncture or bend the battery with any tools while removing the SSD port—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert one tine of a pair of pointed tweezers under the top left corner of the SSD port connector's shield (where the cable is oriented down).
  57. Microsoft Surface Pro X Battery Replacement, Remove the shield: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the shield: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SSD port connector's shield.
    • If the shield isn't completely detached from the frame, pry up additional areas on the edges of the shield.
  58. Microsoft Surface Pro X Battery Replacement, Remove the SSD port sticker: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the SSD port sticker: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to lift up a corner of the black sticker covering the SSD port.
  59. Microsoft Surface Pro X Battery Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SSD port sticker.
  60. Microsoft Surface Pro X Battery Replacement, Disconnect the SSD port: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the SSD port: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the SSD port's press connector from its socket.
  61. Microsoft Surface Pro X Battery Replacement, Disconnect the SIM card reader: crwdns2935265:061crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the SIM card reader: crwdns2935265:061crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the SIM card reader's press connector from its socket.
  62. Microsoft Surface Pro X Battery Replacement, Remove the SSD port screws: crwdns2935265:062crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two 2.5 mm screws securing the SSD port.
  63. Microsoft Surface Pro X Battery Replacement, Remove the SSD port: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the SSD port: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The SSD port cable is lightly adhered to the frame. If the adhesive is too difficult to cut through, continue to the next step for additional removal instructions.
    • Use an opening pick to cut through the adhesive under the SIM card reader socket.
  64. Microsoft Surface Pro X Battery Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the adhesive under the SIM card reader socket is too difficult to cut through, follow these steps to loosen the adhesive:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the SIM card reader socket to loosen the adhesive underneath.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
  65. Microsoft Surface Pro X Battery Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SSD port from the frame.
    • If there's any alcohol solution remaining in the Surface, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your SSD port.
  66. Microsoft Surface Pro X Battery Replacement, Remove the foam adhesive: crwdns2935265:066crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the foam adhesive: crwdns2935265:066crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the foam adhesive: crwdns2935265:066crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the foam adhesive strip from the Surface.
  67. Microsoft Surface Pro X Battery Replacement, Remove the front camera shield: crwdns2935265:067crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the front camera shield: crwdns2935265:067crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one tine of a pair of pointed tweezers under one corner of the shield covering the front camera connector.
  68. Microsoft Surface Pro X Battery Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:068crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:068crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step for the other three corners of the shield.
  69. Microsoft Surface Pro X Battery Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:069crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one tine of a pair of pointed tweezers under the left edge of the shield to further detach it from the frame.
    • Repeat this for the right edge of the shield.
  70. Microsoft Surface Pro X Battery Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:070crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:070crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one tine of a pair of pointed tweezers under the bottom left edge of the shield to further detach it from the frame.
    • Repeat for the bottom right edge.
  71. Microsoft Surface Pro X Battery Replacement: crwdns2935265:071crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:071crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one tine of a pair of pointed tweezers into the divot in one of the tabs on the bottom edge of the shield.
    • You could also insert the tine under the bottom edge of the shield.
    • Lift up the bottom edge to detach it from the frame.
  72. Microsoft Surface Pro X Battery Replacement: crwdns2935265:072crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:072crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:072crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to lift up the bottom edge of the shield so that it is at a 30° angle with the frame.
    • This will detach the top edge of the shield from the frame.
    • Remove the front camera shield from the frame.
  73. Microsoft Surface Pro X Battery Replacement, Remove the rear camera shield: crwdns2935265:073crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the rear camera shield: crwdns2935265:073crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one tine of a pair of pointed tweezers under one corner of the shield covering the rear camera connector.
  74. Microsoft Surface Pro X Battery Replacement: crwdns2935265:074crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:074crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:074crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step for the remaining three corners of the shield.
  75. Microsoft Surface Pro X Battery Replacement: crwdns2935265:075crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:075crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of pointed tweezers to lift up the left side of the shield.
  76. Microsoft Surface Pro X Battery Replacement: crwdns2935265:076crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:076crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide one tine of a pair of pointed tweezers under the bottom right edge of the shield to fully detach it from the frame.
  77. Microsoft Surface Pro X Battery Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the shield covering the rear camera connector.
  78. Microsoft Surface Pro X Battery Replacement, Remove the camera foam strip: crwdns2935265:078crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the camera foam strip: crwdns2935265:078crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the foam strip adhered to the front camera, Windows Hello face camera, and left microphone cables.
  79. Microsoft Surface Pro X Battery Replacement, Remove the Surface Connect port screws: crwdns2935265:079crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the two 2.8 mm screws securing the Surface Connect port.
  80. Microsoft Surface Pro X Battery Replacement, Dislodge the Surface Connect port: crwdns2935265:080crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Dislodge the Surface Connect port: crwdns2935265:080crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Surface Connect port connector can be disconnected before moving the port, but the connector is difficult to reconnect while the port is fully seated. During reassembly, it is easier to reconnect the connector before seating the port into its recess.
    • Use the flat end of a spudger to pry up the left screw tab and dislodge the Surface Connect port from the frame.
    • You only need to lift the port high enough to insert the pointed end of a spudger into the screw tab.
  81. Microsoft Surface Pro X Battery Replacement, Detach the Surface Connect port: crwdns2935265:081crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Detach the Surface Connect port: crwdns2935265:081crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger into the left screw tab.
    • Push the Surface Connect port toward its connector to detach its magnets from the frame.
    • You only need to push the port enough to detach it from the frame and grab it with your fingers. Don't bend the cable more than necessary.
  82. Microsoft Surface Pro X Battery Replacement, Move the Surface Connect port: crwdns2935265:082crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Move the Surface Connect port: crwdns2935265:082crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the edges of the Surface Connect port with your fingers.
    • Pull the port away from the edge of the frame and place it on top of the edge.
  83. Microsoft Surface Pro X Battery Replacement, Disconnect the Surface Connect port: crwdns2935265:083crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the Surface Connect port: crwdns2935265:083crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the foam on top of the Surface Connect port's connector.
    • Lift up on the foam to open the connector's locking tab.
  84. Microsoft Surface Pro X Battery Replacement: crwdns2935265:084crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:084crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:084crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the flat end of a spudger under the left edge of the connector's locking tab.
    • While holding the Surface Connect port with your fingers, push the connector out of its socket in the direction of the cable.
    • If this doesn't fully disconnect the connector, repeat this step for the right edge of the locking tab. Alternate between the left and right edge as needed.
  85. Microsoft Surface Pro X Battery Replacement, Remove the Surface Connect port: crwdns2935265:085crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the Surface Connect port: crwdns2935265:085crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Surface Connect port from the frame.
    • During reassembly, make sure to fully insert the Surface Connect port connector into its socket. The internal metal edge of the connector should be directly adjacent to the metal edge of the socket.
  86. Microsoft Surface Pro X Battery Replacement, Remove the USB-C port shield screws: crwdns2935265:086crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the three 2.9 mm screws securing the first USB-C port shield.
  87. Microsoft Surface Pro X Battery Replacement, Remove the first USB-C port shield: crwdns2935265:087crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the first USB-C port shield: crwdns2935265:087crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the first USB-C port shield: crwdns2935265:087crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are going to reuse the USB-C port shields, try to avoid excessively bending them during removal.
    • Insert one tine of a pair of pointed tweezers into the gap in the first USB-C port shield next to the screw hole closest to the left speaker.
    • Lift up the shield to detach it from the frame.
  88. Microsoft Surface Pro X Battery Replacement: crwdns2935265:088crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the first USB-C port shield from the frame.
  89. Microsoft Surface Pro X Battery Replacement, Remove the second USB-C port shield: crwdns2935265:089crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the second USB-C port shield: crwdns2935265:089crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the second USB-C port shield: crwdns2935265:089crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't pry up the USB-C port shield near the battery—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert one tine of a pair of pointed tweezers under one of the shield's corners closest to the left speaker recess.
    • Slide the tine along the edge of the shield to detach the corner from the frame.
  90. Microsoft Surface Pro X Battery Replacement: crwdns2935265:090crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:090crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:090crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Note that the second USB-C port shield may fling off of the frame when you detach it. You can place a finger on the shield to prevent it from flinging.
    • Repeat the previous step for the other corner of the shield closest to the left speaker recess.
    • Continue prying up the edge of the shield closest to the left speaker recess until the shield detaches from the frame.
    • Remove the shield from the frame.
  91. Microsoft Surface Pro X Battery Replacement, Remove the USB-C port press connector screws: crwdns2935265:091crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two 2 mm screws securing the USB-C port press connector.
  92. Microsoft Surface Pro X Battery Replacement: crwdns2935265:092crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:092crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the long edge of the USB-C port press connector.
    • Rotate the flat end of the spudger to disconnect the press connector from its socket.
  93. Microsoft Surface Pro X Battery Replacement, Remove the USB-C port screws: crwdns2935265:093crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two 2.7 mm screws securing the USB-C port.
  94. Microsoft Surface Pro X Battery Replacement, Remove the USB-C ports: crwdns2935265:094crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the USB-C ports: crwdns2935265:094crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the USB-C ports: crwdns2935265:094crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to grip the USB-C port screw hole tab closest to the left speaker.
    • Lift up the press connector edge of the USB-C ports to detach it from the frame.
    • Remove the USB-C ports from the frame.
  95. Microsoft Surface Pro X Battery Replacement, Disconnect the sensor bar components: crwdns2935265:095crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the sensor bar components: crwdns2935265:095crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Disconnect the sensor bar components: crwdns2935265:095crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the right microphone press connector from its socket.
    • Disconnect the rear camera.
  96. Microsoft Surface Pro X Battery Replacement: crwdns2935265:096crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:096crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:096crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the front camera, the Windows Hello face camera, and the left microphone.
  97. Microsoft Surface Pro X Battery Replacement, Motherboard shield information: crwdns2935265:097crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Motherboard shield information: crwdns2935265:097crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two shields on the motherboard covering screws that secure it to the frame:
    • One square shield to the right of the USB-C port.
    • One rectangular shield to the right of the camera connector sockets.
  98. Microsoft Surface Pro X Battery Replacement, Remove the two shields: crwdns2935265:098crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the two shields: crwdns2935265:098crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the two shields: crwdns2935265:098crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Avoid prying near the battery while removing the shields—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Note that the shields may fling off of the frame when you detach them. You can place a finger on the shield to prevent it from flinging.
    • Insert one tine of a pair of pointed tweezers under a corner of the square shield.
    • Continue to pry up additional areas around the edges of the shield until it detaches from the frame.
    • Remove the square shield.
    • If you are going to reuse these shields, try to avoid excessively bending them during removal.
  99. Microsoft Surface Pro X Battery Replacement: crwdns2935265:099crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:099crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:099crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to remove the rectangular shield.
  100. Microsoft Surface Pro X Battery Replacement, Remove the front-facing sensor bar screws: crwdns2935265:0100crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the eight 5.5 mm screws securing the front-facing sensor bar.
  101. Microsoft Surface Pro X Battery Replacement, Dislodge the front-facing sensor bar: crwdns2935265:0101crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Dislodge the front-facing sensor bar: crwdns2935265:0101crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger into the gap on the right side of the sensor bar between the rightmost screw hole and the adjacent screw hole.
    • Lift up the right side of the sensor bar to dislodge it from the frame.
    • You only need to lift the sensor bar so that it is loose in the frame. Don't try to remove the front sensor bar—it is still attached to the Surface by a cable that connects under the motherboard.
  102. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0102crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0102crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the gap in the sensor bar between the second and third screw hole from the left.
    • This gap is where the sensor bar's cable is located.
  103. Microsoft Surface Pro X Battery Replacement, Lift the front-facing sensor bar: crwdns2935265:0103crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motherboard has spring connectors that fit under the front-facing sensor bar. Lifting the sensor bar makes it easier to remove and replace the motherboard.
    • Lift the sensor bar about 30° out of its recess.
    • Don't push the sensor bar past 90° and don't rotate it horizontally to avoid damaging the cable connecting it to the motherboard.
  104. Microsoft Surface Pro X Battery Replacement, Remove the motherboard screws: crwdns2935265:0104crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the six 2 mm screws securing the motherboard.
  105. Microsoft Surface Pro X Battery Replacement, Remove the motherboard: crwdns2935265:0105crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the motherboard: crwdns2935265:0105crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the motherboard: crwdns2935265:0105crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the motherboard about a half-centimeter above the frame.
    • You only need to lift the motherboard high enough for it to clear the battery as you slide it out.
    • Hold the motherboard on the left and right edge.
  106. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0106crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0106crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0106crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the motherboard down toward the bottom edge of the Surface to remove it from the frame.
  107. Microsoft Surface Pro X Battery Replacement, Detach the battery connector: crwdns2935265:0107crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Detach the battery connector: crwdns2935265:0107crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Detach the battery connector: crwdns2935265:0107crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery connector at the top edge of the battery is lightly adhered to the frame.
    • Insert an opening pick under the peg hole on the left side of the conenctor.
    • Slide the opening pick to the top left corner of the battery connector.
  108. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0108crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0108crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick toward the battery to cut through the adhesive under the left side of the battery connector.
  109. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0109crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0109crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick toward the battery to cut through the adhesive under the right side of the battery connector to fully detach it from the frame.
  110. Microsoft Surface Pro X Battery Replacement, Remove the battery screw: crwdns2935265:0110crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the 2.2 mm screw securing the battery to the frame.
  111. Microsoft Surface Pro X Battery Replacement, Remove the battery: crwdns2935265:0111crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement, Remove the battery: crwdns2935265:0111crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is secured to the frame with strong adhesive. Removing the battery will require weakening and cutting through the adhesive.
    • The battery is divided into four cells. In the following procedure, you'll detach each cell separately from the frame.
    • Prop the top edge of the Surface up a couple inches so the whole Surface slopes toward the bottom edge.
  112. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0112crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top left edge of the battery.
    • If you are using adhesive remover, follow these preparation steps first.
    • Let the adhesive remover sit and soak into the adhesive for 2–3 minutes before continuing.
  113. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0113crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0113crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • The top edge of the battery rests on a shelf. You'll need to insert your pry tools between this shelf and the battery to cut through the adhesive.
    • Insert a side of an opening pick about 2 mm under the center of the top edge of the top left battery cell.
  114. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0114crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0114crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Plastic Cards
    $2.99
    • Slide the opening pick to the top left corner of the cell to create a gap for the plastic card to be inserted.
  115. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0115crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0115crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0115crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a plastic card under the left side of the top edge of the cell to cut through the adhesive.
    • If you encounter significant resistance at any point during this procedure, stop, apply a little more adhesive remover, and wait for it to soak in.
  116. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0116crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0116crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Prop the bottom edge of the Surface up a couple inches so the whole Surface slopes toward the top edge.
  117. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0117crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0117crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the bottom edge of the battery.
  118. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0118crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0118crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a side of an opening pick about 2 mm under the bottom left edge of the bottom left battery cell.
    • Slide the opening pick toward the center of the battery to create a gap for the plastic card to be inserted.
  119. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0119crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0119crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic card under the left side of the cell to cut through the adhesive.
  120. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0120crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0120crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the bottom left battery cell isn't fully detached, repeat the previous step for the right side of the cell.
  121. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0121crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0121crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the battery detaching procedure for the bottom edge of the bottom right battery cell:
    • Insert a side of an opening pick 2 mm under the bottom edge of the battery cell.
    • Slide the opening pick toward the center of the battery to create a gap for the plastic card.
    • Slide a plastic card under the right side of the bottom edge of the battery cell to cut through the adhesive.
    • If the battery cell isn't fully detached, slide a plastic card under the left side of the cell.
  122. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0122crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0122crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0122crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top right edge of the battery.
  123. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0123crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0123crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the battery detaching procedure for the bottom edge of the top right battery cell:
    • Insert a side of an opening pick 2 mm under the top edge of the battery cell.
    • Slide a plastic card under the right side of the top edge of the battery cell to cut through the adhesive.
  124. Microsoft Surface Pro X Battery Replacement: crwdns2935265:0124crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0124crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro X Battery Replacement: crwdns2935265:0124crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift each side of the battery with a plastic card and make sure all the adhesive is separated from the battery.
    • Gently lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • During reassembly, follow this guide to clean off old adhesive and apply new adhesive from a pre-cut adhesive card.
    • Be sure that the Surface Pro X frame surface is completely clean and free of debris. An uneven surface can press into the replacement battery, resulting in premature battery failure.
    Wow. Designed to never be replaced! I wonder if the EU can get replaceable batteries the same way they arm-wrestled a certain company to adopt usb-c across all their mobile devices... .
    Daniel Berzsenyi - crwdns2934203:0crwdne2934203:0
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46,199 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
What on earth is wrong with the designers of this products? Why on earth should some-one have to go through 124 steps to change a battery? Just design a product where you can unscrew the back and replace the battery.
Ben Davies - crwdns2934203:0crwdne2934203:0
How can they sell you the next latest, greatest, fanciest model if you keep fixing your old one? It's called "Planned Obsolescence". I mean, mine lasted 6 years of hard use when my battery died. I got a good long life. But, I have bought dud laptops before. Did not even get 6 months out of a couple of HP laptops. After 6 years, I am ready for an upgrade (even though the old one works just fine for everything I do). After seeing this (very nicely written article with images and instructions - wow!, I have decided to upgrade rather than try to diss-assemble the entire device. It still works fine with plug-in AC charger. I think I will donate it if anyone will take a 6 year old laptop any more.... But, if someone is going to try, you couldn't get a better set of instructions on how to do it. Great job with the article guys....
Nuggehalli Gopal - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 199
crwdns2942667:0crwdne2942667:0 7,975
