Microsoft Surface Pro 6 Kickstand Replacement
  1. Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
    Heute selbst durchgeführt. Hilfreich wäre, die Beschreibung um folgende Info zu ergänzen: wie man die Scharniere nach Schritt 4 wieder aus den Einbuchtungen im Gehäuse hochgestellt bekommt, um das neue Kickstand zu montieren. Nach eigenen Überlegungen konnte ich die Schaniere durch Einführen des benutzten Torx-Schraubenziehers in die äußere Schraubenbohrung des Scharniers und ganz behutsamen Hochdrücken des Scharniers mit Hilfe des Schraubenziehers lösen.
    Oliver Bendig - crwdns2934203:0crwdne2934203:0
Sarah Westberg
crwdns2935283:003/11/19crwdne2935283:0
30.112 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Staff
crwdns2935297:019.996crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Any way to replace the hinges themself?
Only-Wonder - crwdns2934203:0crwdne2934203:0
Also trying to find this out.
Bobby Stephenson -
Thank you so much. I use the Surface 6 in portrait mode to read and use the kickstand as a grip/hand rest to prevent wrist strain. This meant the screws came loose constantly and I had to try and tighten them using my fingertip; not ideal. With the newly purchased Manta kit, and this guide, they are properly tightened again for the first time in over a year.
Chris Goodluck - crwdns2934203:0crwdne2934203:0
If you find that that the kickstand screws are still coming loose, I suggest applying a dab of blue Loctite (or nail polish if in a pinch) to the screws to help them hold in place.
Arthur Shi -
The hinge mechanism has come completely loose so that the stand will not glide back into position. I thought it was the adhesive pads keeping it in place. Reading the instructions above, I now see that these pads can be put back into position. There is a whole Youtube showing the headaches of this kickstand hinge situation. The best bet is to buy a cover with a kickstand attached.
zsugahill - crwdns2934203:0crwdne2934203:0
Thanks for the useless information on how to turn a screw! The hinges are broken! Why else would I be replacing the kickstand? The flap itself has no moving parts to break! How do you replace the hinges??? You've wasted my time and your own time writing the most obvious trash.
jyjg - crwdns2934203:0crwdne2934203:0
Wow, that sounds like such an annoying problem to have with your device! Unfortunately this guide only shows a walk-though for the stand itself. We don’t have a guide for that specific repair but we’d love if you made one! We rely on our amazing community members to help us complete our guide collections so that we can help everyone repair every thing. Head over to our Contribute page and click on “Create a new repair guide” to get started. If you follow the steps of our Surface Pro 6 Battery Replacement, it should get you pretty far into the repair. Good luck!!
Sarah Westberg -
crwdns2936753:030crwdne2936753:0 86
crwdns2942667:0crwdne2942667:0 22,669
