Microsoft Surface Pro 6 Kickstand Replacement
  1. Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
Sarah Westberg
crwdns2935283:003/11/19crwdne2935283:0
31,463 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,044crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Any way to replace the hinges themself?
Only-Wonder - crwdns2934203:0crwdne2934203:0
Also trying to find this out.
Bobby Stephenson -
Thank you so much. I use the Surface 6 in portrait mode to read and use the kickstand as a grip/hand rest to prevent wrist strain. This meant the screws came loose constantly and I had to try and tighten them using my fingertip; not ideal. With the newly purchased Manta kit, and this guide, they are properly tightened again for the first time in over a year.
Chris Goodluck - crwdns2934203:0crwdne2934203:0
If you find that that the kickstand screws are still coming loose, I suggest applying a dab of blue Loctite (or nail polish if in a pinch) to the screws to help them hold in place.
Arthur Shi -
The hinge mechanism has come completely loose so that the stand will not glide back into position. I thought it was the adhesive pads keeping it in place. Reading the instructions above, I now see that these pads can be put back into position. There is a whole Youtube showing the headaches of this kickstand hinge situation. The best bet is to buy a cover with a kickstand attached.
zsugahill - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 22,798
