Microsoft Surface Pro 4 Left Speaker Replacement
  1. Microsoft Surface Pro 4 Left Speaker Replacement, Remove the CPU shield: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement, Remove the CPU shield: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  2. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the last step at various locations around the perimeter of the EMI shield covering the heat sink.
    • Remove the CPU shield.
  3. Microsoft Surface Pro 4 Left Speaker Replacement, Unscrew the heat sink: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx screwdriver to remove two screws from the heat sink:
    • One 2.4 mm screw along the top of the rectangular plate covering the battery.
    • Make sure you don't lose this bracket, as it might separate from the heatsink.
    • One 2.2 mm screw along the bottom of the rectangular plate covering the battery
  4. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The heat sink is firmly adhered to the fan.
    • Use a Phillips screwdriver to remove three 2.4 mm screws securing the fan.
    • Use a T5 Torx screwdriver to remove the final 4.4 mm screw securing in the fan cover.
  5. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the heat sink screws surrounding the CPU in the following pattern, one turn at a time, until they're free.
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
    • During reassembly, use the same method to install these screws, tightening one turn at a time until each screw is snug.
  6. Microsoft Surface Pro 4 Left Speaker Replacement, Remove the heatsink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement, Remove the heatsink: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to gently pry the heat sink straight up and off of the CPU.
    • Take care not to dent or crease the heat sink pipes during removal.
  7. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger into a screw hole in the fan shield and lift up to separate it from the fan.
    • The fan shield is held in place with light adhesive.
  8. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Microsoft Surface Pro 4 Left Speaker Replacement, Left Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement, Left Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the speaker connector from the motherboard.
  10. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screws from the speaker.
    • 2mm Torx T5 screw
    • 3 mm Torx T5 screw
  11. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work the speaker out with your fingers.
    • The speaker is still wedged tightly into the frame and is difficult to remove.
  12. Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Left Speaker Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the speaker, the volume button and the power button from the Surface Pro 4.
Andrew Prater
crwdns2935283:002/01/16crwdne2935283:0
5.809 crwdns2915208:0crwdne2915208:0
Metro State, Team 1-3, Carpenter Spring 2016 crwdns2935289:0Metro State, Team 1-3, Carpenter Spring 2016crwdne2935289:0
MSU-CARPENTER-S16S1G3
crwdns2942667:0crwdne2942667:0 32
