Microsoft Surface Laptop 3 15" Display Assembly Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the display connector shields: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the display connector shields: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the display connector shields: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry up the black shield covering the right bank of display connectors.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Repeat at different points around the shield until it becomes loose.
    • Remove the shield.
  2. Microsoft Surface Laptop 3 15" Display Assembly Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to remove the remaining shield from the left bank of display connectors.
  3. Microsoft Surface Laptop 3 15" Display Assembly Removal, Disconnect the display cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Disconnect the display cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
  4. Microsoft Surface Laptop 3 15" Display Assembly Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three remaining display connectors.
  5. Microsoft Surface Laptop 3 15" Display Assembly Removal, Reassembly tip: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Reassembly tip: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case.
  6. Microsoft Surface Laptop 3 15" Display Assembly Removal, Tilt open the screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the screen as far as it will go.
  7. Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove four hinge screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove four hinge screws: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove four hinge screws: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When removing the hinge screws, make sure to hold the screen steady as it will become more and more loose as the hinge screws are gradually removed.
    • While holding the screen steady, use a T6 Torx driver to remove the four outermost 5.9 mm screws securing the screen, two on each side.
    • Leave the two innermost hinge screws in place for now, one on each side.
  8. Microsoft Surface Laptop 3 15" Display Assembly Removal, Tilt the screen vertical: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly tilt the screen until it's approximately vertical.
    • During reassembly, with the first two hinge screws tightened in place, the screen is free to tilt open for installation of the remaining four hinge screws.
  9. Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the final hinge screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the final hinge screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the screen steady, use a T6 Torx driver to remove the two remaining 5.9 mm screws securing the screen, one on each side.
    • With these two final screws removed the screen will be freed from the rest of the device, so hold it steady.
    • If the screen is exactly perpendicular to the lower case, a screwdriver handle may contact the display during removal. If you're having trouble, lightly tilt the screen back enough to clear the driver.
  10. Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 3 15" Display Assembly Removal, Remove the screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the screen straight up and off of the lower case to remove it.
    • During reassembly, ensure the replacement screen's hinges are at a 90 degree angle with the display.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Carsten Frauenheim
144,841 crwdns2915208:0crwdne2915208:0
crwdns2935297:0423crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021,113crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 45
