Use this guide to remove or replace the touchpad on a Microsoft Surface Laptop 3 (13.5").
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Flip the laptop over and place it on your work surface, feet facing up.
Each foot has a hidden indent that will simplify removal.
To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
Push the spudger underneath the foot and pry up to release it.
Repeat to remove the second rear foot.
Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
Repeat to remove the second front foot.
Note that the front and rear feet are different.
Note that the front feet are directional and only clip in one way.
Peel a pad away from its backing, align it over a foot cavity, and press to secure.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
Flip the device over.
Open the display as far as it will go.
Grip the top edge of upper case above the keyboard and lift straight up to release it.
Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
Remove the ribbon cable from the motherboard.
Remove the upper case.
Set the upper case onto a clean surface, keyboard-side down.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the two pieces of metallic tape covering the top edge of the touchpad cover.
Use a T3 Torx driver to remove the eight 2 mm screws securing the touchpad cover.
Use a pair of tweezers to remove the touchpad cover.
Use an opening tool to pry up the shield covering the touchpad connectors.
Remove the shield.
Use the pointed end of a spudger to lift up the small locking flap on the first ribbon cable's ZIF connector.
Use the pointed end of a spudger to lift up the small locking flaps on the second and third ribbon cables.
Use a pair of tweezers to slide the first ribbon cable out of its connector.
Use a pair of tweezers to slide the second and third ribbon cables out of their connectors.
Set the second ribbon cable—the keyboard and touchpad cable—aside for now.
Use a T5 Torx driver to remove the six 2.9 mm screws securing the touchpad.
Lift up the upper case and hold it above the work surface.
Push the touchpad up through the case and towards the keyboard, freeing it from its front tab.
Remove the touchpad.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
