Microsoft Surface Book Keyboard Battery Replacement
  1. Microsoft Surface Book Keyboard Battery Replacement, Howdy! Let's get started - Gather Your Tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Jimmy
    $7.95
    • You should use an iFixit jimmy tool, a set of screwdrivers conaining a Torx T4, and a phillips bit, and an iOpener. You can be risky like me and use a hair dryer and a scraper! The T4 is necessary though
    • Jimmy Tool
    • iOpener
    • Heat up the area until unpleasant to touch using a heat gun or hair dryer.
    • This should be around 130 degrees Fahrenheit.
    • Careful! Don't get too brave! Heat guns get hot very quickly.
    • Use your jimmy to PRY!!!! PRY ruthlessly!!!!!
    • Please be careful. Do not actually pry ruthlessly.
    • Insert jimmy.
    • Tilt the jimmy flat.
    • Give a pick a little room to insert.
    • pull out the jimmy.
    • Insert into a different location on the device
    • In the video, the device had already been opened and replaced, which is why it seems easier to open
  2. Microsoft Surface Book Keyboard Battery Replacement, Cable Disconnection: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cable from the battery to the motherboard.
    OK - More details here would be helpful.
    Timothy Suhr - crwdns2934203:0crwdne2934203:0
  3. Microsoft Surface Book Keyboard Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Book Keyboard Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the back panel from the top panel
    • Heat up the back panel to about 130 degrees Fahrenheit.
    • Heating up batteries can be dangerous, Proceed with caution
    • Grab a nonmetal bucket, and fill it with sand. (1/2 gallon should do it)
    • This is in case the batteries get punctured or catch fire when being removed.
    • If you notice that you have punctured the battery or notice a sweet, metallic smell, throw the backplate into the bucket, and move the bucket and yourself outside.
    • See here: iFixit Battery Safety
    • Gently, take your opening picks, and VERY, VERY gently, scrape the adhesive out from under the battery.
    • Put the batteries in the bucket and take them to a nearby battery recycling facility. battery recycling facility list
    • Unpackage your new, beautiful, fantastic Surface Book Keyboard battery.
    • Take that battery, and take some of that adhesive, stick it to the back of the battery.
    • Put it on the backplate.
    • Plug in the connector that was keeping you from being able to pull the backplate off.
    • Take your adhesive, line the edges with the adhesive and put the backplate back on
Congratulations! You did it!
TYSM for reading this guide!
Aj Chiappini
crwdns2935283:008/30/23crwdne2935283:0
330 crwdns2915208:0crwdne2915208:0
Which adhesives should I purchase for this replacement?
Gabriel A Ohnstad - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 203
crwdns2942667:0crwdne2942667:0 5,684
