Metal Snap Installation Using a Hand Press
  1. Metal Snap Installation Using a Hand Press, Metal snap types: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Metal snap types: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two main styles of metal snaps on Patagonia gear:
    • Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
    • Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
    • Each piece of the snap has its own corresponding snap die. Make sure you use the correct size and style of snap.
  2. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This tutorial will demonstrate with the Durable Socket Snap, but the same actions can be applied to the Flat Spring Snap.
    • Gather the stud and post pieces and their corresponding dies.
    • The stud and post are compressed together with the press to create the base of the snap.
  3. Metal Snap Installation Using a Hand Press, Insert the post into the post die: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the post into the post die: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the post into the post die: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
  4. Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the post die into the lower fitting of the hand press.
  5. Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the stud piece into the stud die until it snaps into place.
  6. Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
    • Insert the die upward and hold it in place.
    • Tighten the tightening mechanism.
  7. Metal Snap Installation Using a Hand Press, Install the snap base: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap base: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap base: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
    • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
    • Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
    • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
    • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
  8. Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the handle of the hand press and remove the fabric.
    • Inspect both sides of the snap to make sure:
    • It's laying flat and tight up against the fabric.
    • It doesn't spin in place.
    • It fastens together securely with the head of the snap.
    • If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
  9. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gather the socket and cap pieces and their corresponding dies.
    • The socket and cap are compressed together with the press to create the head of the snap.
  10. Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
  11. Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the cap die into the lower fitting of the hand press.
  12. Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the socket piece into the socket die until it snaps into place.
  13. Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  14. Metal Snap Installation Using a Hand Press, Install the snap head: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap head: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap head: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  15. Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It fastens together securely with the base of the snap.
  16. Metal Snap Installation Using a Hand Press, Examples: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Examples: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
    • The duffel bag in the second photo has durable socket metal snaps at the handle grip.
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
90.040 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.006crwdne2935297:0
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 21,708
