Metal Snap Installation Using a Hand Press
    1. Metal Snap Installation Using a Hand Press, Metal snap types: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Metal snap types: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There are two main styles of metal snaps on Patagonia gear:
      • Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
      • Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
      • Each piece of the snap has its own corresponding snap die. Make sure you use the correct size and style of snap.
    2. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • This tutorial will demonstrate with the Durable Socket Snap, but the same actions can be applied to the Flat Spring Snap.
      • Gather the stud and post pieces and their corresponding dies.
      • The stud and post are compressed together with the press to create the base of the snap.
    3. Metal Snap Installation Using a Hand Press, Insert the post into the post die: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the post into the post die: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the post into the post die: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
    4. Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the post die into the lower fitting of the hand press.
    5. Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the stud piece into the stud die until it snaps into place.
    6. Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
      • Insert the die upward and hold it in place.
      • Tighten the tightening mechanism.
    7. Metal Snap Installation Using a Hand Press, Install the snap base: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap base: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap base: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
      • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
      • Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
      • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
      • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
    8. Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Release the handle of the hand press and remove the fabric.
      • Inspect both sides of the snap to make sure:
      • It is not cracked, crushed, or misshapen.
      • It's laying flat and flush up against the fabric.
      • It doesn't spin in place.
      • It fastens together securely with the head of the snap.
      • If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
    9. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gather the socket and cap pieces and their corresponding dies.
      • The socket and cap are compressed together with the press to create the head of the snap.
    10. Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
    11. Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the cap die into the lower fitting of the hand press.
    12. Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the socket piece into the socket die until it snaps into place.
    13. Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    14. Metal Snap Installation Using a Hand Press, Install the snap head: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap head: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Metal Snap Installation Using a Hand Press, Install the snap head: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    15. Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Quality control: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • It fastens together securely with the base of the snap.
    16. Metal Snap Installation Using a Hand Press, Examples: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Metal Snap Installation Using a Hand Press, Examples: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
      • The duffel bag in the second photo has durable socket metal snaps at the handle grip.
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
91,032 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
crwdns2936753:07crwdne2936753:0 56
crwdns2936753:030crwdne2936753:0 283
crwdns2942667:0crwdne2942667:0 25,578
