Meta Quest 2 USB‑C Port and Headphone Jack Replacement
  1. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Power off your Meta Quest 2: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the facial interface: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the facial interface: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the eyepiece trim screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the eyepiece trim screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  6. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Release the eyepiece trim clips: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Release the eyepiece trim clips: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  7. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  8. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  9. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reposition the eyepiece trim: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reposition the eyepiece trim: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reposition the eyepiece trim: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  10. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the face sensor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the face sensor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the face sensor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  11. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  12. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the eyepiece trim: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eyepiece trim.
  13. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  14. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  15. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the front cover screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the front cover screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the front cover screws: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  16. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Release the front cover clips: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Release the front cover clips: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  17. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  18. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the front cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front cover.
  19. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the top right antenna: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the top right antenna: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the top right antenna: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  20. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the battery cable bracket: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  21. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  22. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the battery: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the battery: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  23. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the antenna: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the antenna: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the antenna: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  24. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Loosen the front antenna assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Loosen the front antenna assembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  25. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  26. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to unclip the antenna cable from its metal clip.
  27. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the front antenna assembly: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front antenna assembly.
  28. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the fan: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the fan: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  29. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Loosen the LED flex cable: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Loosen the LED flex cable: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  30. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the fan assembly: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  31. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan assembly and remove it.
  32. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the heat sink: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
  33. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the heat sink and remove it.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of viscous thermal compound (such as K5 Pro) to the processor.
  34. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, stop here and check if these twelve connectors are properly connected to the motherboard:
    • Two speaker connectors
    • Seven ZIF connectors
    • Two press connectors
    • One antenna connector
    • There are additional connectors on the motherboard, but they shouldn't be connected at this point.
  35. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the speaker connectors: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the speaker connectors: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the speaker connectors: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to grip the left speaker cables at the base of their motherboard connector.
    • Lift the connector gently straight up to disconnect it.
    • During reassembly, use the flat end of a spudger to press the speaker cable into the rubber holding clip.
  36. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the disconnection procedure for the right speaker connector.
  37. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the ZIF socket flex cables: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the ZIF socket flex cables: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to gently peel the black tape covering the two top flex cables.
    • Set the tape aside to be reused during reassembly.
  38. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
  39. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
  40. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
    • Power button and LED board
    • Bottom left camera
    • Bottom right camera
    • Top right camera
    • Face sensor interconnect cable
    • Indicator LED cable
  41. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the press connectors: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the press connectors: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Disconnect the press connectors: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the display cable.
  42. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
  43. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
  44. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the motherboard: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws securing the motherboard to the headset:
    • Four 3.8 mm‑long Phillips screws
    • One 6 mm‑long 3.5 mm hex standoff screw
  45. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point, the motherboard should be loose, with some thermal paste sticking it to the headset.
    • Use a spudger to pry up and separate the motherboard from the headset.
    • If it feels like the motherboard is caught on something, check that all the cables are disconnected from it.
  46. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard.
  47. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the camera covers: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the camera covers: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the camera covers: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
    • During reassembly, align the cutouts on the camera covers to their respective pegs on the headset.
    • The camera covers have different alignment cutouts and aren't interchangeable.
  48. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Loosen the screen and lens assembly: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Loosen the screen and lens assembly: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel and remove the black tape covering the antenna cable.
    • Set this tape aside to be reused during reassembly.
  49. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
  50. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
    • Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
  51. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the procedure to disconnect the right microphone cable.
  52. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
  53. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Some interconnect cables have been removed in the following images for clarity purposes. You don't have to remove them as part of the procedure.
    • Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
    • Two 6.5 mm‑long screws
    • Two 7.7 mm‑long screws
  54. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the screen and frame assembly: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the screen and frame assembly: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the screen and frame assembly: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the screen and lens assembly with your fingers.
    • Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
    • Remove the screen and lens assembly.
  55. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Reassembly note: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
    • Three cables along the top edge—two flex cables and one LED flex cable
    • Two cables in the top right corner—the battery connector and an antenna cable
    • Two cables along the right edge—an antenna cable and a wide flex cable
    • Two flex cables along the bottom edge
    • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
    • You can use a rubber band to help secure the cables out of the way.
  56. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Unclip the left speaker cable: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Unclip the left speaker cable: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Unclip the left speaker cable: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to guide the left speaker cable out of its two plastic clips.
    • Clip this cable neatly into the guide clips to prevent it from getting pinched by the screen and lens assembly.
    • The first guide clip should clip behind the rubber stop on the speaker cable. This anchors the cable while giving it enough slack for the speaker arm to swivel.
  57. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the left outer speaker bracket: crwdns2935265:057crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the left outer speaker bracket to the outer shell.
  58. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:058crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the outer speaker bracket off of the gaskets securing it to the speaker assembly.
    • Remove the left outer speaker bracket.
  59. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the USB‑C port and headphone jack: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 4.5 mm‑long screws securing the USB‑C port and headphone jack to the outer shell.
  60. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or tweezers to pull the USB‑C port and headphone jack off of the screw posts.
  61. Meta Quest 2 USB‑C Port and Headphone Jack Replacement, Remove the port bracket: crwdns2935265:061crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 3.5 mm‑long screws securing the USB‑C port and headphone jack to its bracket.
  62. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grasp the screw post on the headphone jack, closest to the USB-C port.
    • Lift the edge to swing the headphone jack module out of its recess.
  63. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to lift the USB-C port out of its recess.
  64. Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 USB‑C Port and Headphone Jack Replacement: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the USB-C port and headphone jack from its bracket.
crwdns2935229:08crwdne2935229:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298.119 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.807crwdne2935297:0
thank you for the guide, I was able to change the charging port and is now working. unfortunately, the headset is not able to see the controllers. by any chance you know what might cause this?
thank youuu
gonzalo escamez - crwdns2934203:0crwdne2934203:0
Had this just happen to me too I can get a charge now but once i turn it on it boots up takes me to the lock screen then locks out the controllers and headtracking just to go to a black screen and stay there until i try and restart it again. I'm guessing it might be a bad connection on either the proximity sensor or the cameras but I'm not sure
Joseph Maldonado -
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 134
crwdns2936753:030crwdne2936753:0 588
crwdns2942667:0crwdne2942667:0 8,642
