Meta Quest 2 Headset Battery Replacement
crwdns2942287:0crwdne2942287:0This guide shows how to remove and replace a worn out battery in your Meta Quest 2 headset.
The battery is positioned above the screen and lens assembly and requires significant disassembly in order to reach it.
Note: You'll need a long PH00 bit or a dedicated PH00 screwdriver to remove some recessed screws.
- K5‑PRO Viscous Thermal Pastecrwdns2942747:0crwdne2942747:0crwdns2943225:0crwdne2943225:0crwdns2931591:0Amazoncrwdne2931591:0
crwdns2944105:0crwdne2944105:0
Hold the power button for three seconds to fully turn off your headset.
Grasp and pull on the nose section of the facial interface to unclip it from the headset.
Photos of each step and interim made this guide so easy to follow.
Grasp and pull on the top section of the facial interface to unclip it from the headset.
Use your fingers to grasp the right strap near the headset.
Peel the right strap away from the headset arm to unclip it.
Repeat the procedure to peel the left strap away from the arm to unclip it.
Separate the hook and loop strip on the top strap.
Unthread the top strap from its bracket.
Remove the head strap.
Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
Leave the opening pick in the seam to prevent the clips from reengaging.
Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
Set the trim down on your work surface, making sure not to strain the cable.
Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to pull the face sensor cable out of the ZIF connector.
Remove the eyepiece trim.
Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
Use a spudger to press the lock tab down towards the cable to lock it in place.
Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
One recessed in the top-left corner
One recessed in the top-right corner
Three along the lower edge
Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
Pry with the opening pick to release the front cover clips.
Slide the opening clip along the seam and pry to release all the clips securing the front cover.
Remove the front cover.
Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
Lift the antenna connector straight up to disconnect it.
Guide the antenna cable out of its metal clip holding it in place.
Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
One 4.4 mm‑long screw
Two 2.3 mm‑long screws
Use tweezers or your fingers to grasp the battery cable bracket.
Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
Remove the battery cable bracket.
Use a spudger to pry up and disconnect the battery press connector from the motherboard.
Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
Four 4.4 mm‑long screws
Two 4.8 mm‑long screws
Two 10.7 mm‑long screws
I love the way you color-coded each set of screws to help with organization!
Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
Use tweezers to unclip the antenna cable from its metal clip.
Remove the front antenna assembly.
Use tweezers to grab the fan connector and carefully slide it out of its socket.
Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
Remove the two screws securing the fan assembly to the headset:
One 4.4 mm‑long Phillips screw
One 3.6 mm‑long Torx T2 screw
Lift the fan assembly and remove it.
Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
Use your fingers to lift the heat sink and remove it.
Two speaker connectors
Seven ZIF connectors
Two press connectors
One antenna connector
Use tweezers to grip the left speaker cables at the base of their motherboard connector.
Lift the connector gently straight up to disconnect it.
Repeat the disconnection procedure for the right speaker connector.
Use tweezers to gently peel the black tape covering the two top flex cables.
Be careful not to pull the cable from the connector. Take extra care on this step.
Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
Power button and LED board
Bottom left camera
Bottom right camera
Top right camera
Face sensor interconnect cable
Indicator LED cable
Use a spudger to pry up and disconnect the display cable.
Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
Remove the five screws securing the motherboard to the headset:
Four 3.8 mm‑long Phillips screws
One 6 mm‑long 3.5 mm hex standoff screw
Use a spudger to pry up and separate the motherboard from the headset.
Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
Peel and remove the black tape covering the antenna cable.
Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
Repeat the procedure to disconnect the right microphone cable.
Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
Tried this and the display cable broke because it probably wasn't adhesive
Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
Two 6.5 mm‑long screws
Two 7.7 mm‑long screws
Grasp the screen and lens assembly with your fingers.
Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
Remove the screen and lens assembly.
Three cables along the top edge—two flex cables and one LED flex cable
Two cables in the top right corner—the battery connector and an antenna cable
Two cables along the right edge—an antenna cable and a wide flex cable
Two flex cables along the bottom edge
Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the battery to the outer shell:
Two along the front edge
Four along the back edge
Use your fingers or tweezers to remove the top strap bracket.
Lift and remove the headset battery.
Slide an opening pick under the face sensor interconnect cable to loosen the adhesive securing it to the battery.
Remove the sensor interconnect cable.
Only the headset battery remains.
You can remove the three T2 screws and to lift the metal cover off of the battery assembly to access the cell. The cell is secured with weak adhesive. Pour a bit of IPA into the tray and after a few minutes, use picks to pry the cell free of tray. Take your time with this to avoid cracking the tray.
Once the cell is free, you can carefully peel away the strip of black tape from the top of the cell which allows you to slide the plastic cap off the cell and expose the main positive and negative terminals that directly connect the cell to the protection pcb. This provides a safer way to test the cell.
You can detach the cell from the protection board and replace it with one that will fit the tray or try to charge it.
My cell measured 2.0V. I am attempting to use a cheap TP4056 module to charge the cell up to full. A TP4056 will trickle charge a low cell up to about 3.5V and then will switch to normal charging rate up to 4.2V. I'll post a follow up comment if I have any success with this. -
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:019crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Life is too short.
I followed this to change the battery in my son's headset amd I have to say it was a life saver. Very well written and detailed, the photos and coloured circles were of particular help. Thanks for the effort - I'm about to use it again to replace the motherboard! Really frustrating that with a few simple design changes Meta could have made this a five minute job, but well done for helping us all out! :)
This was a well written and very thorough how to guide that tool a lot of dedication and I commend you for it. I am contemplating taking on this endeavor on behalf of my adult son who was gracious enough to allow me to use his machine and I am now a huge fan, just in time for the battery to wear out. Still debating if I will attempt but know for sure I would not even begin.to consider it without your guide. Thank you for such a selfless endeavor!
Many thanks!!!
I disassembled my quest because I have water damage. I have cleaned all corrosion, but I would like tot test the battery before I reassemble. How can I check if the battery is in good condition?
Check voltage on the pins with a multimeter? If it’s well below 3.85v then it’s no good. You can try revive it, but I wouldn’t recommend it unless you know what you are doing 🤓
Mike -
This guide made the job fun. Thanks!
where do you get the replacement battery? Thank you!
I found a couple on Amazon, which I imagine you have by now as well, but there may be better options available.
Jon R -
One Weird Trick Meta Doesn't Want You To Know: Amazing set of instructions. Thank you so much for your effort. It is a daunting task to replace the Occulus battery, but this guide has helped to ease the pain as much as possible.
Fantastic guide. Really easy to follow. I struggled with the tape on step 41 and accidentally pulled a cable out before releasing the clip so take care on this step.
Mmm osea las baterías están justo detrás de las pantallas, si explotan dios no lo quiera adiós a los ojos ?!
This step is too hard please clarify?
4 Frog - crwdns2934203:0crwdne2934203:0
This step is too confusing please clarify you &#@.
