Mercedes W123 Diesel Short Bypass Coolant Hose Replacement
  1. Mercedes W123 Diesel Short Bypass Coolant Hose Replacement, Short Bypass Coolant Hose: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mercedes W123 Diesel Short Bypass Coolant Hose Replacement, Short Bypass Coolant Hose: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mercedes W123 Diesel Short Bypass Coolant Hose Replacement, Short Bypass Coolant Hose: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Required: In order to remove your short cooling bypass hose you will first need to remove the thermostat housing. The thermostat housing gasket will need to be replaced, with fresh gasket sealant, at the end of this job. For guidance on removing the housing and replacing the gasket [crwdns2936915:0crwdne2936915:0]
  2. Mercedes W123 Diesel Short Bypass Coolant Hose Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Diesel Short Bypass Coolant Hose Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the short coolant hose to be replaced. You can see it leaking in this picture. This is a typical failure.
    • During the thermostat housing removal process you'll have already loosened the upper hose clamp on the short hose. Now loosen the lower clamp.
    • With the lower clamp removed you'll be able to pull the short hose off the water pump inlet.
    • Use a pair of pliers for grip if you need to, but it should pull off by hand.
    this job was a pain for me although, I finally got it. Since I drained the coolant, I also replaced the  upper and lower radiator hoses, thermostat  and reinforced the upper radiator neck.  For better access,  it helps to remove the turbo duct and the short air filter tube. I also had to tap on the thermostat housing to free it from the head….it was hard to see the seam between the two but after some scraping and cleaning it was obvious.
    Bob - crwdns2934203:0crwdne2934203:0
  3. Mercedes W123 Diesel Short Bypass Coolant Hose Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the short hose off of the car.
    • Measure its length, and then mark that length on the bulk hose you purchased.
    • Use a utility knife or other appropriate cutting tool to cut the length of hose you need to replace the old short hose.
    • Install the new hose, and then re-install the thermostat housing and gasket.
Nicolas Siemsen
crwdns2935283:012/06/13crwdne2935283:0
39,953 crwdns2915208:0crwdne2915208:0
crwdns2935297:079crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,422crwdne2935297:0
I just wanted to say thank you to Nicolas Siemsen for this piece. I am yet to do it because I am yet to buy the piece of hose. But seeing how clearly he wrote the article with pictures I am confident that I can do it. Thanks again.
ony632000 - crwdns2934203:0crwdne2934203:0
You're welcome!
Nicolas Siemsen -
Tips: Be sure to replace the clamps with new worm-drive type having combination hex-slot screw heads. These are far superior to original type. Also be sure to orient the clamps so screw heads point toward front of car and next to the cylinder head. The latter is necessary for proper clearance as air conditioning bracket sits adjacent to thermostat housing on some versions. Take time to carefully situate the hose clamps as they are almost impossible to access once compressor bracket is in place. Also take time to clean metal surfaces to which the hose connects - lightly sand or scour with metal brush to remove deposits - assuring proper seal is important before assembly.
analogcd - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 7,799
