Maze Speed SSB-508 Screen Replacement
    1. Maze Speed SSB-508 Screen Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
    2. Maze Speed SSB-508 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove fifteen 2mm Phillips #00 screws.
    3. Maze Speed SSB-508 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the plastic opening tool up at the bottom left corner to create the gap.
      • Repeat this through all corners to remove the internal casing.
    4. Maze Speed SSB-508 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the 2mm screw at the bottom right of the motherboard.
      • Remove the internal antenna casing from the motherboard.
    5. Maze Speed SSB-508 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the speaker at the top of the motherboard.
    6. Maze Speed SSB-508 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
    7. Maze Speed SSB-508 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
      • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
      • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
    8. Maze Speed SSB-508 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • At this point, the motherboard should be able to be lifted up from the bottom.
      • Use the tweezers to dislodge the speaker.
      • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
      • Using a soldering tool, desolder the cable from the back of the motherboard.
    9. Maze Speed SSB-508 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard from the back.
    1. Maze Speed SSB-508 Screen Replacement, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maze Speed SSB-508 Screen Replacement, Screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Apply the heated iOpener to all sides of the screen (left, right, top, and bottom) for 90 seconds (or more if necessary) to soften the adhesive.
    2. Maze Speed SSB-508 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Jimmy's flexible steel blade to separate the screen from the frame. Insert the blade between the frame and screen then carefully lift using the blade.
      • Gently lift the glass screen and remove from the frame.
    3. Maze Speed SSB-508 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Maze Speed SSB-508 Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • There will be a thin flat cable at the top of the screen in which you need to carefully peel back.
    4. Maze Speed SSB-508 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Move the connecting wire through the hole at the top frame.
      • Then, remove the glass screen and replace with the new one.
To reassemble your device, follow these instructions carefully in reverse order.
Jun Soo Kim
crwdns2935283:007/08/19crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G3, Watkins Summer 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G3, Watkins Summer 2019crwdne2935289:0
ERAU-WATKINS-SU19S3G3
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,545
