Mayflash Arcade Stick F300 Printed Circuit Board Replacement
  1. Mayflash Arcade Stick F300 Printed Circuit Board Replacement, Metal Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Printed Circuit Board Replacement, Metal Backplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Printed Circuit Board Replacement, Metal Backplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Printed Circuit Board Replacement, Printed Circuit Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mayflash Arcade Stick F300 Printed Circuit Board Replacement, Printed Circuit Board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
  3. Mayflash Arcade Stick F300 Printed Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Printed Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Printed Circuit Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
    • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
    • Use a metal spudger to gently remove the softened glue.
    • Unplug the cable from the socket.
  4. Mayflash Arcade Stick F300 Printed Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mayflash Arcade Stick F300 Printed Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently unplug the rest of the attached wires from the PCB.
    • Make sure to keep track of where each wire goes to assist with reassembly.
  5. Mayflash Arcade Stick F300 Printed Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the printed circuit board.
Follow these instructions in reverse order to reassemble your device.
Kellason Walker
crwdns2935283:009/04/24crwdne2935283:0
115 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-4, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-4, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G4
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 286
