Marshall Kilburn II Main Speaker Replacement
  1. Marshall Kilburn II Main Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the front of the Marshall Kilburn II on a flat surface so the back is facing you.
    • Use a Phillips #1 screwdriver to remove all ten 4 mm screws.
  2. Marshall Kilburn II Main Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the charging port cover.
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws.
  3. Marshall Kilburn II Main Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly lift up the back cover of the speaker just enough to be able to see the inside compartment of the speaker.
    • Take care not to strain the attached cables.
    • You can use an opening tool to help pry up the back cover from the sides if the back cover doesn't lift up easily.
    • Lift the back cover just enough to be able to see the inside compartment of the speaker.
  4. Marshall Kilburn II Main Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery, which is attached on the inside bottom left corner. Refer to image 1.
    • Identify the black cable that connects from the battery to the back cover of the speaker.
  5. Marshall Kilburn II Main Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the white battery connector and pull it directly out of its socket.
    • Remove the battery by pulling the battery up out of its housing.
    • You will need to cut the white zip tie which holds the battery cable and the other cables together.
  6. Marshall Kilburn II Main Speaker Replacement, Main Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement, Main Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly press on the tab on the speake connector and pull up to disconnect it.
    • Disconnect the two speaker connectors.
    • Avoid using excessive force when pulling the wires to avoid damages.
  7. Marshall Kilburn II Main Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Main Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove all six 4 mm screws securing the main speaker.
    • Be mindful of the strong magnetic pull from the speaker.
    • Remove the main speaker.
david Angoran
crwdns2935283:008/28/24crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 1-2, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S1G2
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 525
