Marshall Kilburn II Battery Replacement
  1. Marshall Kilburn II Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the front of the Marshall Kilburn II on a flat surface so the back is facing you.
    • Use a Phillips #1 screwdriver to remove all ten 4 mm screws.
  2. Marshall Kilburn II Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the charging port cover.
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws.
  3. Marshall Kilburn II Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly lift up the back cover of the speaker just enough to be able to see the inside compartment of the speaker.
    • Take care not to strain the attached cables.
    • You can use an opening tool to help pry up the back cover from the sides if the back cover doesn't lift up easily.
    • Lift the back cover just enough to be able to see the inside compartment of the speaker.
  4. Marshall Kilburn II Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn II Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery, which is attached on the inside bottom left corner. Refer to image 1.
    • Identify the black cable that connects from the battery to the back cover of the speaker.
  5. Marshall Kilburn II Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn II Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the white battery connector and pull it directly out of its socket.
    • Remove the battery by pulling the battery up out of its housing.
    • You will need to cut the white zip tie which holds the battery cable and the other cables together.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Kelvin Mark
crwdns2935283:008/28/24crwdne2935283:0
458 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 1-2, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S1G2
This happened after <6 month service, I was about to replace batt but found:
Turn on the speaker, then push and hold the Bluetooth pairing button for at least 20 seconds. When you release the button, the speaker should restart.”
Ck this first BUT a replacement batt is always good idea.
Cheers From AZ. -Davison Sends
Jeff Davison - crwdns2934203:0crwdne2934203:0
my killburn doesn't respond when unplugged, but works fine when plugged in, but the red charging indicator shows the battery is charging indefinitely.
Pedro Ho - crwdns2934203:0crwdne2934203:0
I'm not able to change the battery as I'm not able to lift up the back cover.. it stuck..
e2mlow - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 243
crwdns2942667:0crwdne2942667:0 1,929
