Marshall Emberton Button Replacement
Asia Baldwin
crwdns2944107:0crwdnd2944107:0Asia Baldwincrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0December 27, 2022crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The main button on top of the Marshall Emberton speaker is used to navigate between tracks and also the volume. This guide provides detailed instructions on how to replace the main button on the Emberton Bluetooth speaker.
With constant pressure on the button, it may eventually wear out and stop working. Replacing the button is very simple and only requires a TR-9 screwdriver.
crwdns2944105:0crwdne2944105:0
  1. Marshall Emberton Button Replacement, Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
  3. Marshall Emberton Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
  4. Marshall Emberton Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
  5. Marshall Emberton Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
Asia Baldwin
crwdns2935283:009/26/22crwdne2935283:0
724 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-1, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 5-1, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S5G1
where can i find a replacement button
MANU 1907 - crwdns2934203:0crwdne2934203:0
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - crwdns2934203:0crwdne2934203:0
yes, i confirme !!!
Mallet Jp -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 2,344
