crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
crwdns2959928:0crwdne2959928:0 ↓Warning: Battery replacement can be dangerous! Exercise extreme caution when following this guide!
Drain the battery below 25% to avoid battery thermal run-away.
Wedge spudgers and picks between the acrylic and the metal/plastic bottom.
Use a pry tool or spudger to unlatch four plastic clips around the perimeter of the inner compartment.
Open the mouse carefully, like a book. A ribbon cable connects the two halves.
Remove the two Torx T5 screws holding the metal cowling over the cable connector.
Disconnect the cable from the board and set the top half of the mouse aside.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
Pull off the black rubber stopper from your bottle of adhesive remover.
Use scissors to cut off the sealed tip of the applicator.
Apply a 2 drops of adhesive remover evenly.
Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery.
Get a spudger under the battery and pry it up off the glue.
Pull the charging port out of place.
crwdns2935229:033crwdne2935229:0
crwdns2947412:017crwdne2947412:0
I may be wrong because I don’t own this device, but from what I’ve read from other tutorials, it does not look like it’s necessary to do steps 1 and 2. The tutorials I’ve read just split the mouse in 2 without messing with the bottom of the mouse. Doing so means they don’t need to worry about damaging the bottom or working with the adhesive.
ComputerWhiz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have fixed it!
Thanks for the note!
Ben Capehart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
you are right 1st and 2nd are unnecessary steps, but hats off to the creator for showing, grat job! thanks
FixMyMacLK - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Die Anleitung ist leider sehr unvollständig.
Nachdem das Maus Kabel und das Batterie Kabel entfernt wurde, ALLE Schrauben entfernen (4er und 5er Torx), die Platine, den Schalter und die Metall Spange demontieren. Den Ladestecker abschrauben, Achtung! darunter befindet sich eine Metallhülse / Führung für den Ladestecker, gleich mit entfernen.
Jetzt darf nur noch die Batterie zu sehen sein.... Ab in den Backofen und auf 50 Grad Celsius erwärmen, das reicht aus, um die Batterie ohne Schaden am Gehäuse zu entfernen. Die Klebestreifen befinden sich links und rechts auf den langen Seiten. Diese im warmen Zustand sofort ablösen und auf die neue Batterie kleben.
Beim Zusammenbau darauf achten, die etwas längeren Schrauben gehören zum Schalter! Die Stecker vorsichtig ohne Gewalt einstecken, wenn alles richtig ist, gehen sie ganz leicht herein.
So, ich hoffe das ich nichts vergessen habe, Viel Glück
Michael Fischer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Translation:
Unfortunately, the instructions are very incomplete.
After the mouse cable and the battery cable have been removed, remove ALL screws (4 and 5 Torx), dismantle the board, switch and metal clasps. Unscrew the charging plug, attention! Below it is a metal sleeve / guide for the charging plug, immediately remove it.
Now only the battery can be seen.... Put it in the oven and heat it up to 50 degrees Celsius, that's enough to remove the battery without damaging the housing. The adhesive strips are located on the left and right on the long sides. Remove them immediately when warm and stick them to the new battery.
When assembling, make sure that the slightly longer screws belong to the switch! Gently plug in the plugs without force, if everything is correct, they go in very easily.
So, I hope I haven't forgotten anything, good luck
