This guide will demonstrate how to replace a damaged rubber gasket on the blender blade lid of your cup. The rubber gasket is responsible for sealing the cup from leaking. Other possible problems can be found in our Troubleshooting Guide.
Unscrew the blending blade lid from the cup.
Use tweezers to peel back the rubber gasket that surrounds the inner ring of the lid.
Now what?
bthull@rogers.com
What is step three…
bthull@rogers.com
Is the gasket supposed to be loose or glued in place?
His Step 3 is to "Reverse the process" which is NOT helpful at all. I think I would need about 4 hands to keep the gasket in the groove while turning the base to complete the circle. This was not usefull!
AWESOME! No more leaks. Such an easy fix. Thank you
thanks but how do you get the new gasket back on????????
