crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Device Will Not Turn On
When attempting to start or turn on the device, nothing happens.
Unplugged Device
If the device does not turn on, check to make sure the it is plugged into the wall.
Cup is Not Fully Inserted
If Device will not start, make sure that the blender cup is fully secured to the base.
Faulty Cord
If the plugged in device is not starting when the activators are fully pressed down, there could be a faulty cord (link will direct you to the repair guide).
The Cup Leaks
When blending, the cup leaks fluid.
Setup Problem
The blender cups were meant to be screwed on snug. If loose or screwed on poorly, it may leak.
Overfilling the Cup
The blender cups also have a max fill line. Filling the cup past the marked line may also cause the cup to leak.
Faulty Seal
If the lid is properly screwed on and the cup is still leaking, this may be a problem with a faulty rubber gasket (link will direct you to the repair guide).
Damaged Cup
If the lid and seal are secured and leaking still occurs, there may be a crack or chip in the cup through which fluid can leak. Cracks or chips may also prevent proper threading between blender cup and lid. The accessories can be replaced here.
The Blades Do Not Turn
The blender is on and receiving power but does not activate when plugged in.
Unplugged Device
If the device will not start, make sure that the blender cup is fully secured to the base.
Stuck Activators
If the blades do not turn, your activators may be stuck. Apply a small amount warm water to the activators to loosen any dirt or juice residue. Then attempt to force stuck activators down by pushing down on the stuck activator (one at a time).
Broken Activators
For the Magic Bullet to operate, small tabs called activators need to be fully functional. If the blades refuse to spin when the cup is fully secured and the activators are fully pushed down at the same time, there may be an issue with the Activators Functionality (link will direct you to the repair guide).
Brett Crews
crwdns2935283:010/02/16crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-4, Forte Fall 2016 crwdns2935289:0Cal Poly, Team 18-4, Forte Fall 2016crwdne2935289:0
CPSU-FORTE-F16S18G4
crwdns2935297:048crwdne2935297:0
crwdns2944067:019crwdne2944067:0
Can’t unscrew the blade part from the cup. Smoothie inside. Help!
Joann Manzek - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Magic Bullet does not have a Max fill line!!
Beryl Walker - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
can not unscrew blade from cup
MARGIE - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The blue light is flashing and the blades won’t turn.
shelleygarb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Used the nutra bullet a few times- tried to make a smoothly and it didn’t start
Sharon orenstein - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 106
crwdns2959996:0crwdne2959996:0 22,951
