Magic Bullet NutriBullet Power Cord Replacement
crwdns2942287:0crwdne2942287:0Is there a tear or cut in your cord? If so, refer to this guide to replace the power cord. This guide will require some soldering experience.
crwdns2944105:0crwdne2944105:0
Before beginning, make sure the device is unplugged.
With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
Once the screws are removed, pull the plastic base up gently.
"Once the screws are removed, pull the plastic base up using slight tension as you pull."
I will leave the second line as it is
Gently lift the power cord from its side slot and place it to the side.
"Gently lift the power cord from its slot and place it to the side."
Hi I just want to know where I can buy the plastic little fan of the nutribullet?
With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
"With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket."
(The white safety bracket holds the cord down) After removing it, the cord will be free.
After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
Gently pull out the two plastic covers at the end of the wires.
Now the wires will be free.
Locate the end of the wires and gently pull the two plastic covers off.
Use tape or clamps to hold the wires together for an easy soldering experience.
Using a soldering iron, solder your new wire to the red wire.
Using tape or clamps to hold the wires together will allow for an easy soldering experience.
Line 2= as it is
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:07crwdne2947412:0
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Can I plug the Magic Bullet in 220v?
Where can I get a replacement cable from?
Any recommendations on where to get the replacement power cord?
I just followed this guide and it worked perfectly, and for what its worth i didnt do any soldering - many thanks!
It would be better to switch these points around because if someone begins unscrewing the screws and the device is plugged in, who knows what might happen. It's better to put the warning first instead of second.
I would correct the first line to read, "With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base."
Jonathan Fernandez - crwdns2934203:0crwdne2934203:0
