Having trouble turning on your Magic Bullet? This guide will help you replace the power cord.
Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
Remove the white plastic cable guide.
Remove the two crimp caps from the end of the wires.
Separate the black wires of the power cord from the red wires on the Magic Bullet base.
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
Where do we get a new power cord, and if that does not work, what do we do next?
