Magic Bullet MB1001B Activator Replacement
crwdns2942287:0crwdne2942287:0Are you having trouble getting your Magic Bullet to turn on? Are the plastic activator tabs on your Magic Bullet broken off? This guide will help you replace the activators.
crwdns2944105:0crwdne2944105:0
Use pliers to grip the gear inside of the top of the device.
Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
Remove the white plastic cable guide.
Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
Remove the three white rubber spacers with the spudger.
White rubber spacer is broke from where to get one in colombon
Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
How is called the cover held by the 3 screws? Can be bought somewhere?
will U give me feedback? If U have a part # will be great!
Mine is broken, the rest is perfect! Thanks!
Wedge a flathead screwdriver in between the casing and white plastic activator.
Pry the white plastic activators from the casing as needed.
Do you know of anywhere to just buy the activator part for this machine? Thanks
Where can I buy the “white plastic activators”?
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:04crwdne2947412:0
You gotta be kidding me?
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Where would you get replacement activators or spring beneath these? How much would that cost?
Oh, my gosh! I’ll just throw this thing away and use my blender!
Can you replace the base gear in a Mini Bullet? I am having a hard time unscrewing it.
Margaret Bellanger - crwdns2934203:0crwdne2934203:0
