Use this guide to replace the battery in your MacBook Pro 16" 2023.
This model MacBook uses stretch-release adhesive strips, some of which are underneath the trackpad. You'll need to remove the trackpad to access these strips.
You'll need replacement adhesive to complete this repair if your new battery doesn't come with it.
If your battery is swollen, take appropriate precautions.
Note: This laptop uses a combination of standard Torx and Torx Plus (IP) screws. In the case that you don't have all the necessary Torx Plus drivers, you can use standard Torx drivers instead. If you do, make sure to use constant, downward force to avoid stripping.
Some photos in this guide are of the previous model MacBook Pro and may contain slight visual discrepancies, but they won't affect the procedure.
Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
Unplug the MagSafe cable and any accessories connected to your MacBook.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a P5 pentalobe driver to remove the eight screws securing the lower case:
Four 9.1 mm‑long screws
Four 6 mm‑long screws
Apply a suction handle to the center of the lower case's front edge.
Pull up on the suction handle to create a gap between the lower case and the frame.
Insert an opening pick into the gap.
Slide your opening pick around the bottom right corner and up the right edge of the lower case.
Slide your pick until it reaches the middle of the cutout, or until the rightmost clip stops it from sliding.
Twist your pick to release the two right clips.
Slide your opening pick around the bottom left corner and up the left edge of the lower case.
Slide your pick until it reaches the middle of the cutout, or until the leftmost clip stops it from sliding.
Twist your pick to release the left two clips.
Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
Remove the lower case.
Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
Use a 3IP Torx Plus driver to remove the two 2.1 mm screws securing the trackpad cable bracket.
Remove the bracket.
Use the flat end of your spudger to pry up and disconnect the trackpad cable press connector from the logic board.
Peel the trackpad cable from the battery board.
Move the cable over the front edge of the MacBook.
Peel back the tape covering the battery data cable connector on the logic board.
Use the point of a spudger or a clean fingernail to flip up the small locking flap on the battery data cable ZIF connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Slide one arm of your blunt nose tweezers under the battery data cable.
Grip the cable just below the head of the connector.
Slide the connector straight out of its socket.
Peel back the tape covering the battery data cable connector on the battery board.
Use the point of your spudger or a clean fingernail to flip up the small locking flap on the battery data cable ZIF connector.
Use blunt nose tweezers to grab the battery data cable just under the head of the connector and slide it straight out of its socket.
Peel the cable from the battery board and the logic board.
Remove the cable.
Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery connector.
Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
Use your T5 Torx driver to remove the 13 screws securing the trackpad:
Ten 5 mm screws
Three 5.8 mm screws
Open your MacBook slowly. The trackpad will remain on the screen.
Guide the trackpad cable through its slot in the frame.
Remove the trackpad.
Four rectangular washers
Five circular washers
Use your T5 Torx driver to remove the two screws securing the battery board to the frame:
One 4.4 mm screw
One 3.8 mm screw
Eight strips along the left and right edges of the battery
Six strips accessed from the trackpad recess
Use blunt nose tweezers or your fingers to grip the black pull tab on one of the adhesive strips.
Pull the strip out slowly and at a low angle to the frame. Give it plenty of time to stretch and un-stick.
If a strip breaks off, try to retrieve it from under the battery with your fingers.
Repeat this process for all 14 stretch-release adhesive strips.
Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) under the battery near the broken adhesive strips.
Wait one to two minutes for the adhesive to soften.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card under each battery cell where the stretch-release adhesive strips broke.
Slice the remaining adhesive and pry up to separate the cells from the frame.
crwdns2935267:0crwdne2935267:0Stretch Release Battery Adhesive$3.99
Slide the battery toward the bottom of the MacBook and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
