MacBook Pro 14" 2021 Speakers Replacement
  1. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" 2021 Speakers Replacement, Unclip the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Unclip the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Release the right clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Release the sliding clips: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
    This straight up does not work on my M4 unit. Pulled as hard as I could and bent the $@$* out of the case and never got it released.
    Christopher Maunder - crwdns2934203:0crwdne2934203:0
    Refer to this guide: https://support.apple.com/en-us/120759
    You basically need to pull the front edge up before attempting to slide out the bottom cover. That worked for me
    Mohammad Afaneh -
  6. MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Remove the lower case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector on the logic board.
    Not strictly necessary to remove this end of the cable, as the other end is also disconnected later. However, it does get it out of the way.
    Patrick - crwdns2934203:0crwdne2934203:0
  8. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
    Can I use my hand at this stage?
    Lou Juntao - crwdns2934203:0crwdne2934203:0
  9. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the trackpad cable bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
    Sorry but this is not correct Apple procedure.
    There is power running through the device still whilst you are unscrewing this plate/bracket and disconnecting the trackpad if you do it this way. This is why Apple put the small flex cable next to this, free to reach before touching anything else.
    You must disconnect the battery flex cable next to the trackpad connector before you touch anything else.
    Thanks
    Brendan Roberts - crwdns2934203:0crwdne2934203:0
    Is that not what steps 7-9 are doing? You cannot actually access the battery connector until you remove this cable as it's underneath. Which battery flex cable are you referring to?
    maccentric -
  11. MacBook Pro 14" 2021 Speakers Replacement, Remove the trackpad cable bracket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Remove the trackpad cable bracket: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the trackpad cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the trackpad cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" 2021 Speakers Replacement, Reposition the trackpad cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Reposition the trackpad cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery board: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  16. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
    Ich hab dieses Datenkabel zerstört. Ist das der Grund warum es nicht mehr lädt?
    Welches Kabel bräuchte ich denn? Das hier Item # IF464-018-1?
    MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485) Battery Daughter Board Cable
    Ray - crwdns2934203:0crwdne2934203:0
  17. MacBook Pro 14" 2021 Speakers Replacement, Remove the data cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Remove the data cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
    Removing is easy. We cant reinsert the battery data cable connector. It wont push in properly. Any helpful solution???
    Paul Smith - crwdns2934203:0crwdne2934203:0
  18. MacBook Pro 14" 2021 Speakers Replacement, Unfasten the battery connector: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
  19. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the battery connector: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
    I would place a piece of card stock (business card) taped to the battery cells so the contact can’t be made.
    Dan - crwdns2934203:0crwdne2934203:0
    I have a question, could you please clarify, if the battery connector is damaged, is it replaceable or I have to replace the whole logic board?
    Saddam Al-Dhaheri - crwdns2934203:0crwdne2934203:0
  20. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the right speaker: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the right speaker: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the tape covering the right speaker ZIF connector.
  21. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to gently pry up the locking flap on the right speaker ZIF connector.
  22. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the right speaker cable by sliding it out from its socket.
  23. MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Disconnect the left speaker: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the procedure in the previous three steps to disconnect the left speaker.
  24. MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Apply isopropyl alcohol: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) in the gap between the speaker and the edge of the frame.
    • Wait for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
  25. MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Separate the adhesive: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick in the gap between the speaker and the edge of the frame.
    • Slide the opening pick along the edge of the speaker to slice the adhesive beneath it.
  26. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick in the gap between the battery and the speaker.
    • Pry up with the pick to separate the speaker from the frame.
    • Take care not to puncture the battery while you pry. If you're having difficulty prying up, apply a few more drops of isopropyl alcohol.
  27. MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the edge of the speaker to separate the adhesive.
  28. MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 14" 2021 Speakers Replacement, Remove the speaker: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the speaker, making sure to peel off any remaining adhesive.
    • Repeat the loosening and separating process for the other speaker.
    • Use a pre-cut adhesive sheet, like Tesa Tape, to secure the speaker back to the frame.
    • Clean up any remaining adhesive from the frame before installing new adhesives.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
169.220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.540crwdne2935297:0
The description up top alludes to having to remove the logic board + fans to replace the speakers, but that doesn't seem to be the case in the step by step. Can anyone who's completed this speaker replacement clear that up?
thardee - crwdns2934203:0crwdne2934203:0
Hi thardee, thanks for pointing that out. You're right, the logic board and fans don't need to be removed to replace the speakers. I've removed that section from the description.
Chayton Ritter -
Can you be clear about what is considered the right speaker? From the images, it appears you are removing the left speaker, as it appears when using the laptop in normal orientation. Obviously, with the base removed and the batteries at the bottom, this will be on the right when working on the laptop. If I were to order a replacement for what I consider to be the right speaker (i.e. the one by my right hand when typing), what should I specify (or do they only come in pairs anyway)?
Tim Holmes - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 334
crwdns2942667:0crwdne2942667:0 10,594
