MacBook Pro 13" Touch Bar 2018 Logic board Replacement
HelloMacOS
crwdns2944107:0crwdnd2944107:0HelloMacOScrwdnd2944107:0crwdnd2944107:0crwdnd2944107:09crwdnd2944107:0crwdne2944107:0
crwdns2944111:0February 25, 2025crwdne2944111:0
crwdns2931291:03crwdne2931291:0
crwdns2937803:0crwdne2937803:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
This guide will take you through the steps of replacing the logic board in your 2018/2019 (A1989)MacBook Pro.
crwdns2944105:0crwdne2944105:0
  1. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • 'sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command (typed into Terminal, as shown above):
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Remove the pentalobe screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Open a gap using a suction cup: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Open a gap using a suction cup: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Separate the clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Separate the clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Separate the clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Remove the lower case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower case.
    Why does this show a logic board with 2 fans? Mine has only 1 fan.
    Cary B - crwdns2934203:0crwdne2934203:0
    If yours only has one it’s the 2 thunderbolt model from another year or a MacBook Air of some sort:-)
    HelloMacOS -
  9. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Uncover the battery connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Uncover the battery connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
    Would be nice to mention the fact you have to lift up the tiny little plastic cable locking device before pulling this ribbon cable out.
  12. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fold the battery board data cable to the side and out of the way.
  13. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  14. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  15. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Remove the trackpad connector screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
    use a t4 for and push down hard the screw on the right, it feels like apple just fcks with us for no reason other than to make it harder to fix these things
    no flex - crwdns2934203:0crwdne2934203:0
    Correct, T3 did not fit - had to use T4
    Joe - crwdns2934203:0crwdne2934203:0
    T5 in MacBook Pro 2019 Touch Bar
    Gustavo Cevallos - crwdns2934203:0crwdne2934203:0
  16. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  17. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  18. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnect keyboard connector: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two screws.
    • Two T3 Torx Screws.
    These are T3 on this machine I'm working on
    Cool_Breeze - crwdns2934203:0crwdne2934203:0
    Thanks for letting me know:-)
    on the machine I was working on I was able to use a T4
    But thanks again for letting me know
    HelloMacOS -
    t3 on left and t4 on right
    no shield or screws on my machine, just tape and a zif connector to flip up and disconnect
    Chuck Urwiler - crwdns2934203:0crwdne2934203:0
  19. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug Left speaker cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel back the black tape to reveal the ZIF connector.
    • Unlatch the ZIF connector by flicking the arm on the connector upwards and carefully remove the cable from the connector by sliding it out.
    • Repeat this process with the newly revealed connector.
    • The two screws that are outlined in yellow are not relevant to this step and are marked on the board itself. For this step, yellow corresponds to the yellow rectangle in the image.
    the bottom one is very very difficult good luck
    make sure you click the piece up before moving the connector ribbons. you will hear a click.
  20. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug left Thunderbolt ports: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug left Thunderbolt ports: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screw have been removed carefully remove the metal shield.
    • Under the metal shield there is a connector, carefully unplug it.
    Thanks for letting my me know:-)
    Il change the size
    When I was taking my one apart I was able to use a T4
    HelloMacOS -
    sometimes t5 needed. ive used t3 and t4 and just before drilling another hole on a whim tried t5
    you are missing a picture of the connecter being unplugged (last step on this) step 20
  21. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug Touch ID and Auxiliary port: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug Touch ID and Auxiliary port: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug Touch ID and Auxiliary port: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T4 Torx driver to remove the two screws.
    • Two T4 Torx screws.
    • Carefully remove the metal shield.
    • Under the metal shield you will find two connectors, carefully unclip them.
    • The second cable you will disconnect will be lightly adhered so carefully slide a plastic spudger under it and finally unplug it.
    • The adhered cable is very thin and delicate so don't rush it and take your time.
    Bear in mind Touch ID is paired to the logic board so if you're replacing the Touch ID along with the logic board, be sure to check the power Touch ID button is mounted correctly and can be depressed before you put the logic board back in. Otherwise you may find yourself taking the board back out again. Don't ask me how I know.
    can we get pictures of the two connectors under the shield
    The screws on mine appeared to be T3, not T4.
    Snipezorz - crwdns2934203:0crwdne2934203:0
  22. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnecting the display connector: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnecting the display connector: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnecting the display connector: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx driver to remove the four screws.
    • 4 T3 Torx screws.
    • Once the screws are removed carefully remove the metal shields.
    • Carefully unclip the connector.
    Bei mir waren die beiden unteren markierten Schrauben nur mit einem Torx T4 lösbar. Außerdem sind sie länger als die oberen Schrauben, was beim Zusammenbau zu beachten war.
    Gregor Tempel - crwdns2934203:0crwdne2934203:0
    upper silver had T4 and thin black clip had T3 screws
    sutherlandralph - crwdns2934203:0crwdne2934203:0
  23. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Disconnect wifi and Bluetooth antennas: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cables carefully with a plastic pry tool.
    • Be gentle, if too much force is applied it can take the board connector up with it.
  24. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Touch Bar cable 1: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Touch Bar cable 1: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Touch Bar cable 1: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal shield carefully.
    • Carefully unplug the connector.
    So where is the touchbar connector on the actual 13 inch Macbook Pro logic board?
    Mine is the A2159. This logic is not the one that mine is.
  25. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Right speaker cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  26. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, ZIF connector: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    What is the exact name of this flex cable?
    Kristof Kajtar - crwdns2934203:0crwdne2934203:0
  27. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug Right Thunderbolt ports: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Unplug Right Thunderbolt ports: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  28. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Touch bar bracket / Flex: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Touch bar bracket / Flex: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Touch bar bracket / Flex: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T4 Torx driver to remove the screw.
    • T4 Torx screw.
    The screw on mine appeared to be T3, not T4.
    Philcom - crwdns2934203:0crwdne2934203:0
    T3 screw on mine too. 1.8mm i suspect author had odd drivers
  29. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Audio socket / Touch ID bracket: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Audio socket / Touch ID bracket: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.4mm screws securing the bracket.
    • Remove the bracket.
    Duplicate of step 21 (although more detailed)
    Shldnet - crwdns2934203:0crwdne2934203:0
  30. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • gently disconnect the audio socket flex cable with a spudger.
    • gently disconnect the Touch ID flex cable with a spudger.
  31. MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Display cable: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Display cable: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Touch Bar 2018 Logic board Replacement, Display cable: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx driver to remove the two 2.4mm screws securing the display cable bracket.
    • Use a T3 Torx driver to remove the two 1.2mm screws securing the display cable bracket.
    • gently disconnect the flex cable with a spudger.
  32. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the six 2.2mm screws securing the logic board.
    • Use a T3 Torx driver to remove the three 1.9mm screws securing the logic board.
    • Use a T5 Torx driver to remove the two 2.3mm (3.7mm head) screws securing the heatsink.
    The screw under the WiFi / Bluetooth antenna cables is slightly longer than the others circled in red, at least in mine. It makes sense as that location has the additional thickness of the metal shield piece that goes between the screw and the hole.
    drlarsen - crwdns2934203:0crwdne2934203:0
  33. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift up the logic board, make sure none of the connectors are connected, also make sure they aren't caught on the logic board.
  34. MacBook Pro 13" Touch Bar 2018 Logic board Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations you have now removed your MacBook's LogicBoard
    You are actually removing the coolers as well, not only the main logic board.
crwdns2935229:015crwdne2935229:0
HelloMacOS
crwdns2935283:001/24/22crwdne2935283:0
26.777 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Hi!
If anyone needs any help just ask me:-)
HelloMacOS - crwdns2934203:0crwdne2934203:0
Bonjour, une fois la carte mère remplacer, comment remettre le nouveau numéro de série et bios à jour svp?
thu huc - crwdns2934203:0crwdne2934203:0
Salut, désolé pour mon mauvais français car j'utilise un traducteur pour cela :-) lorsque vous remplacez la carte logique/carte mère, la nouvelle carte aura son propre bios et son numéro de série, si vous voulez mettre à jour votre bios, il vous suffit de mettre à jour macOS
HelloMacOS -
At what point would you say you need thermal paste?
Kailee Kovach - crwdns2934203:0crwdne2934203:0
You need to replace thermal past every 4years or so…or at least that’s what I do to keep the machine running cool:-)
HelloMacOS -
What about the soft plastic rectangular, 3-sided pieces? Are those cooling guides, or just noise suppressors for the fans? Critical? I didn't see those addressed in your guide.
GamesForOne - crwdns2934203:0crwdne2934203:0
Is the Logic Board the same for all A1989 models? I have a Mac Book from 2018 and one from 2019 and I would like to transfer my logic board from one to the other, if this works.
Falco Lentzsch - crwdns2934203:0crwdne2934203:0
Hi, Can I replace an A1990 (MBP 2018 15) logic board into an A1707 chasis (MBP 2016 15)??? greetings
Erik Ferney Cubillos Garcia - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 111
crwdns2936753:030crwdne2936753:0 450
crwdns2942667:0crwdne2942667:0 19,627
