Follow this guide to replace a broken or jammed headphone jack on your MacBook Pro 2020.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.7 mm screws
Four 3.4 mm screws
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Gently peel back the small piece of tape covering the battery board data cable connector.
Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
Disconnect the battery board data cable by sliding it out from its socket.
Slide parallel to the logic board, in the direction of the cable.
Fold the battery board data cable to the side and out of the way.
Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Use a T3 Torx driver to remove the two 1.8 mm screws securing the headphone jack connector cover.
Use a pair of tweezers to remove the headphone jack connector cover.
Use a T3 Torx driver to remove the three 4.4 mm screws securing the headphone jack to the case.
Use the pointed end of a spudger to pry the headphone jack connector straight up to disconnect it from the logic board.
Remove the headphone jack.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
