MacBook Core Duo Display Replacement
  1. MacBook Core Duo Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the computer.
  3. MacBook Core Duo Display Replacement, Memory Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the battery casing, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Display Replacement, Upper Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. MacBook Core Duo Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. MacBook Core Duo Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. MacBook Core Duo Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. MacBook Core Duo Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. MacBook Core Duo Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. MacBook Core Duo Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. MacBook Core Duo Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. MacBook Core Duo Display Replacement, Optical Drive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
  14. MacBook Core Duo Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips screws from the front edge of the optical drive.
    • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
  15. MacBook Core Duo Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the orange optical drive ribbon cable from the logic board.
  16. MacBook Core Duo Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
  17. MacBook Core Duo Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the (once again) newly-revealed hard drive cable.
  18. MacBook Core Duo Display Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel up the foil tape between the fan and the optical drive.
    • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
  19. MacBook Core Duo Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
  20. MacBook Core Duo Display Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2.8 mm Phillips screw securing the optical drive.
    • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
    • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
    • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
  21. MacBook Core Duo Display Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the Bluetooth antenna board from the right side of the optical drive.
    • Deroute the hard drive cable from along the front of the optical drive.
  22. MacBook Core Duo Display Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the front edge of the optical drive and slide it up and out of the computer.
  23. MacBook Core Duo Display Replacement, C-Channel: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two 3 mm Phillips near the right speaker.
    • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
    • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
  24. MacBook Core Duo Display Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the right speaker out of its housing and set it to the side.
  25. MacBook Core Duo Display Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
  26. MacBook Core Duo Display Replacement, Display: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
  27. MacBook Core Duo Display Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the black right speaker cable with one hand, and deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
  28. MacBook Core Duo Display Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Deroute the silver microphone cable and gray display data cable from the tabs at the bottom of the subwoofer.
  29. MacBook Core Duo Display Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3.2 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
  30. MacBook Core Duo Display Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board. (Pull vertically on all three.)
  31. MacBook Core Duo Display Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 2 screws from the right hinge mount:
    • One 6 mm Phillips on the left side of the hinge mount.
    • One 10 mm Phillips on the right side of the hinge mount.
    • Lift the right hinge mount out of the computer.
  32. MacBook Core Duo Display Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the display with one hand while removing the screws from the left hinge mount.
    • Remove the following 3 screws from the left hinge mount:
    • One 6 mm smaller diameter Phillips from the right side.
    • One 6 mm larger diameter Phillips from the middle.
    • One 10 mm Phillips from the left side.
    • Lift the left hinge mount out of the computer.
  33. MacBook Core Duo Display Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the display assembly on either side, and lift it up and out of the computer.
crwdns2935229:087crwdne2935229:0
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 139,498
