MacBook Air 13" Late 2020 Screen Replacement
  1. MacBook Air 13" Late 2020 Screen Replacement, Remove the screws securing the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    ESD safe mat, plugged into ground, with a wrist strap, also grounded, are the best best to protect the logic board.
    Robin Ray - crwdns2934203:0crwdne2934203:0
    Re-Assembly Tip: Before putting the screws back in, snap the lower case on and test to make sure the MacBook powers up. When I first re-assembled, I became very nervous I did something wrong because it would not power on. It turns out I just needed to plug the laptop into a power source for it to power up (despite having a good charge before disassembly). It was the perfect way to test the new USB-C ports!
    Austin - crwdns2934203:0crwdne2934203:0
    Big points to this one, especially for mentioning needing to plug the laptop in. The bottom case needs to be screwed in and laptop needs to be plugged in before it will boot.
    Bayden Yazalina -
    Wiha 4PL driver for these screws.
    Greg Worrel - crwdns2934203:0crwdne2934203:0
    Printing out all the images from this Ifixit guide prior to starting and using duct tape help me keep track of screws.
    raju midjdeya - crwdns2934203:0crwdne2934203:0
    This Guide has a high chance of not working if an aftermarket display is used as MAC serialization was introduced post ~2023. Likely you will need an original MAC screen replacement and to serialize the display for it to work.
    Tron Computers - crwdns2934203:0crwdne2934203:0
  2. MacBook Air 13" Late 2020 Screen Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Los tornillos se ruedan fácilmente :(
    Mishelle Cerón - crwdns2934203:0crwdne2934203:0
  3. MacBook Air 13" Late 2020 Screen Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
    Reassembly: I had difficulty going straight down. The connector has some angled edges that made it difficult. Instead, I slotted the wire side in first, then rocked it forward towards the hinge into position.
    Sean K - crwdns2934203:0crwdne2934203:0
    If having difficulty in flipping the bar up, place the machine vertical and not that there is a small “locking nib” that the bar has to clear. You may have to give the bar honest persuasion to clear the nib.
    Harry Dulcamara - crwdns2934203:0crwdne2934203:0
    The bar can lock backwards making it very hard to even see let alone move. Great care is needed to shift it. I had to use two thumbnails, one on each side, then once flipped forward it takes more push than I expected to clip it in place. Ensure the plug is fully seated first !
    Simon Anthony - crwdns2934203:0crwdne2934203:0
    As others commented, it can be hard to click the battery connector back into place. First make sure the bar is not underneath the connector. Then, turning the computer so the connector pins are facing you (LCD hinge end closer to you) can also make it easier to position the connector on top and then click it into place.
    madmaxmedia - crwdns2934203:0crwdne2934203:0
    Some replacement batteries have a retainer bar that differs from OEM batteries. I had to swap the retainer bar to properly secure it under the "locking nib" to ensure it didn't release on its own (before it could freely swing).
    Anthony Collier - crwdns2934203:0crwdne2934203:0
  4. MacBook Air 13" Late 2020 Screen Replacement, Disconnect the antenna cables: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
    Wiha tools T3 fit perfectly.
    I found this screw difficult to reinstall. Very small and fiddly. 15-20 minutes on this step.
    To reinstall a tiny screw first turn it counterclockwise until you feel it engage the tread, then turn them clockwise to tighten it.
    Patrick Langvardt - crwdns2934203:0crwdne2934203:0
    If you are not sure if it needed a T3 or T4 (seems people needed one or the other) place the smaller one into the screw head and make sure it feels seated. Same using the T4. It should seat snugly. Snug fit especially important for hinge screws (T8). They can be a bit tight!
    John Nagy - crwdns2934203:0crwdne2934203:0
    I just did one and it needed a T5 to remove this screw.
    John McKee - crwdns2934203:0crwdne2934203:0
  5. MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna cable cover.
    Make sure the 90 degree bend on the cover is towards the hinge when reassembling. It will fit in backwards, but will cause problems.
  6. MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
    • During reassembly, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets.
    These are tiny, and hard to reconnect. The key was to position the cables so their ends are very close to the posts on the board.
    dexter - crwdns2934203:0crwdne2934203:0
    Yep. Good call. Me too folks.
    Harry Dulcamara -
    So anyone that’s had experience with keyboard and antenna, connectors, or previous Apple iPhone products, knows that these antenna connectors go on from front to back so you kind of have to position the noncable end of the antenna cable first and then push it towards the back I’m not sure if that makes sense, but try from the front to the back connecting Put pressure on the front first and then put pressure towards the cable in if you do it wrong and put too much pressure in it, you can ruin the cables. Be careful with it.
    babs martin - crwdns2934203:0crwdne2934203:0
    This was the hardest part of the reassembly for me. One side connected easily, the other took 10 minutes of fanagling. Using the flashlight from my phone up close helped me see better what was going on and then pushing the connector slightly towards the hinge to create more bend on the cable so that it would line up correctly.
    quackerback - crwdns2934203:0crwdne2934203:0
  7. MacBook Air 13" Late 2020 Screen Replacement, Disconnect the display cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
    None of the screws in this repair are T3. All the smaller ones are T4. Which is good, ‘cause my (cheap) repair tool kit doesn’t have a T3.
    The T3 screws called out were indeed T3, not T4 on the MacBook Air I replaced the display on.
    --Mac Ace, Inc.
    I dropped one of these - can they be purchased? Or is there a matching screw in an older MacBook Air? I have a ton of those for parts... :-)
    Jimmy Anderson - crwdns2934203:0crwdne2934203:0
    weird, for my model A2337 it is even T2 screws. tested it two times and I have the ifixit mako precision bit set.
    Otto Klassen - crwdns2934203:0crwdne2934203:0
    On my MacBook Air M1 Early 2020, I had to use a T4 bit on one of the screws. The other one came out with a T3. I am using a HyperTough 77-piece precision repair set.
    Raj Venkat - crwdns2934203:0crwdne2934203:0
    T3 worked on mine, but getting this cover to line up with the holes was tricky due to the slope, it kept sliding out of place. I finally held it in place with one finger while carefully inserting the screw on one side. Once I had that in, then it was easy to line up the other side.
  8. MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display cable connector cover.
    Wth my new assembly, there were no covers for the connectors either side of this cover. I had to transfer them from my original display assembly
    John Haywood - crwdns2934203:0crwdne2934203:0
    Also note that all these covers have one precision hole (ie round) and one 'loose' (ie trapezoid). Fit the round one first, not super tight. Then the second and tighten all
  9. MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Since this step is the most crucial in the reassembly process I suggest connecting the flat cable to the board BEFORE placing the board in to its cavity in the antenna bar. MUCH easier and SAFER to do.
    J Patrick Dowling - crwdns2934203:0crwdne2934203:0
    When putting back together, be sure to not trap the display cable underneath the antenna bar as I did!
  10. MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the six screws securing the antenna bar:
    • Four 7.4 mm silver screws
    • Two 4.7 mm black screws
    When putting it back together, make sure to get the display cable connector out from under the antenna board before screwing the antenna bar back down. The connector has to go behind the bar in the little notch as the board goes through the opening in the bar.
    Matthew Granger - crwdns2934203:0crwdne2934203:0
    Mine here were Torx T4. Came with the kit.
    Jace Sheppard - crwdns2934203:0crwdne2934203:0
    My 4.7 mm screw is stripped.
    Any suggestions to get it removed?
    B S - crwdns2934203:0crwdne2934203:0
    B S,
    Darn, sorry that happened! Here's a guide with five different methods you can try to get it loose: How to Remove a Stripped Screw
    Best of luck!
    Carsten Frauenheim -
    These are T5. A T4 might work but you might strip it.
    A T6 shouldn't fit at all; if it does, your driver is either worn or just poor quality.
    maccentric - crwdns2934203:0crwdne2934203:0
  11. MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger into the gap between the antenna bar and display hinge.
    • Pivot the spudger against the hinge to pry up the end of the antenna bar.
    • Repeat for the other end of the antenna bar.
    This step can’t be accomplished without first loosening the adhesive beneath both right and left metal sides of the bar. I used a heat gun set at 150 degrees with a narrower airflow attachment to carefully heat up just on the metal parts of the bar while slowly applying pressure until the adhesives gives. The first comment on step 12 is also helpful.
    scentaur - crwdns2934203:0crwdne2934203:0
    I didn't have a heat gun and the instructions didn't mention it; managed to pry it off with a bit of force. Though I'd have used a heat gun if it were available.
    Robert Monfera - crwdns2934203:0crwdne2934203:0
  12. MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pry the antenna bar straight up and away from the case.
    • The antenna bar is secured with some adhesive and may require some force to dislodge.
    • Thread the antenna board through the opening in the middle of the antenna bar.
    • Be careful to not put any strain on the antenna bar's ribbon cables.
    • Remove the antenna bar.
    Separating antennae bar from case after removing screws is challenging. Author’s directions are good but what needs to be addressed is a thin strip of adhesive on both sides of the bar that needs to be separated. the strips are located on the hinge edge of the logic board mount area. I used a metal, razor thin, wide, blade type spudger to gently “wedge” underneath the bar along both adhesive strips to loosen the bar and lift it up. Careful!
    Macrepair SF - crwdns2934203:0crwdne2934203:0
    Before removing the antenna bar see if the right side is slightly elevated than the left. Upon replacement I could not get the right side to sit as flush as the left. However it may be intentional to protect the wifi wires.
    I was stuck on this step (removing the antenna bar) but this video helped me: https://www.youtube.com/watch?v=tHhHNjzO...
    Matthias - crwdns2934203:0crwdne2934203:0
  13. MacBook Air 13" Late 2020 Screen Replacement, Remove four hinge screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove four hinge screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total).
    • Each hinge has a third central screw, which you should leave in place for now.
    The Easiest Mac screen repair I've ever done! it was a pleasant surprise
    Kelly Legner - crwdns2934203:0crwdne2934203:0
    I found a T9 to be a better fit
    Luke Knight - crwdns2934203:0crwdne2934203:0
    Nothing is making these screws come out. Any advice on what to do
    ella sharman - crwdns2934203:0crwdne2934203:0
    Increase the diameter of the handle. That gives more torque to break the screww loose. You could wrap it with some material and then cover it with duct tape.
    Matthew Granger -
    TR9 Screw in my Mako Precision Bit set from ifixit.
    Snug fit especially important for hinge screws (T8 or T9). They can be a bit tight!
  14. MacBook Air 13" Late 2020 Screen Replacement, Fully open the MacBook: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Fully open the MacBook: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
  15. MacBook Air 13" Late 2020 Screen Replacement, Remove the two remaining hinge screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the MacBook up and place it on its side, with the display facing away from you.
    I find it easier to place the macbook on a table with keyboard down and the screen hanging over the side. Much less cumbersome, especially when putting the new screen in place.
  16. MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the two remaining 5.0 mm screws securing the display, one from each hinge.
    • Once these screws are removed, the display will no longer be connected to the upper case. Hold both halves steady.
    My first attempt at reassembly had the hinge making a terrible snapping sound due to pushing some plastic parts out of the way at full extension. After screwing in these first two screws, I suggest opening and closing the hinge a few times to confirm it's smooth and quiet. If not, you have a fraction of a millimeter of play to get it into just the right position.
    On disassembly and reassembly, keep in mind that the edge of the leaf of the hinge (the part with the 3 holes in it--red circle in picture above) sits slightly under a metal edge, and the barrel or pivoting part of the hinge is tucked under the forward-sloping edge of the case. This means the hinge doesn't just loosen and come out. It helps to lift the leaf free of the metal edge in front of it. Yes, this takes more force than you think it might. This will allow the entire hinge to be lifted up and forward (toward the front of the computer) out of its place under the edge of the case.
    Robert - crwdns2934203:0crwdne2934203:0
  17. MacBook Air 13" Late 2020 Screen Replacement, Remove the display: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove the display: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Screen Replacement, Remove the display: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully begin to close the display until it's at a ~90 degree angle with the upper case.
    • The hinges should pull out of the case slightly as the display is moved towards the case.
    • Keeping the display at a 90 degree angle with the case, move the display away from the case while holding the case still, so that the hinges slide out the bottom of the case.
    • Remove the display.
    • When you've installed the replacement screen, the MacBook may not boot until you plug in the power supply.
    I managed to try to fit the screen back to the body backwards, and wondered why the hinges didn't fit! Yes, stupid. I lost situational awareness. But just make the sure the correct side of the screen is facing the right way, to avoid my (temporary, but stressful) goofup.
    Me too until I read your comment. Remember that the screen was facing away from you in step 16. Then it fits easily.
    Matthew Granger -
    Like Dexter and Matthew I also initially tried to fit the display on backwards. I'm sure a lot of people are laughing at this mistake but if you're not paying attention it can happen. After 10 minutes having no success mounting the display I looked at the comments and had a DUH moment myself. In the correct orientation the mounting process is straightforward. Thanks Dexter for breaking the ice on this embarrassing situation!
    Patrick Langvardt -
    Nicely done guide, thank you Carsten!
    MotorMac - crwdns2934203:0crwdne2934203:0
    When you're all done with reassembly you have to plug the charger into the laptop in order for it to boot. It doesnt matter if the battery is charged it will not boot until the charger is reconnected. Took me a while to figure out why mine wasnt booting after the screen replacement
    Nelson Pun - crwdns2934203:0crwdne2934203:0
    Yep me too. Use the charger folks.
    Harry Dulcamara -
    Excellent guide. Concise, accurate, very nice!
    I replace the screen and the computer is currently plugged into a power source, however I cannot get the computer to actually turn on. It just shows the charging display icon when I try to turn the computer on.
    Nicole - crwdns2934203:0crwdne2934203:0
    The true tone function will be lost even if you replace the display with a 100% compatible display.
    KazuhiroOshiyama - crwdns2934203:0crwdne2934203:0
    Even the display that is purchased through the Apple Parts store? I have one coming and will report back once I install it.
    Mike Hiteshew -
    Confirmed that all features function as new when using a display from Apple Parts - True Tone, Camera, Nightshift, etc.
    Mike Hiteshew -
    Perfect guide. I didn't encounter any issues and just worked carefully and gingerly.
    Toby Phillippe - crwdns2934203:0crwdne2934203:0
    Great guide - excellent photos and description. Very accurate. Thanks for creating!
    Mike Hiteshew - crwdns2934203:0crwdne2934203:0
    **************************** IMPORTANT SAFETY TIP************************
    I pulled another common mistake probably. Make sure that the screen cable is snaked through to the bottom when reattaching the new screen assembly. I didn't. I got all 6 screws on and closed the screen. I was up to step 12 when I realized there was no antenna board. Luckily it didn't break the screen again when I closed the cover on it!
    Excellent instructions. Did not take long at all. Every step is on point.
    Bayne Schulstad - crwdns2934203:0crwdne2934203:0
    Hey, great instructions - thanks! I'm pretty clumsy, and these screens are pretty fragile, which means I'm currently on my 4th screen! I have replaced them all myself following these instructions, and I've bought genuine parts AFAIK. However, for each replacement, I can never get the camera to work. It shows in System Information like so:
    Model ID: FaceTime HD Camera
    Unique ID: EAB7A68F-EC2B-4487-AADF-D8A91C1CB782
    But it just isn't recognised by any app, and whatever I try (killing all apps that might be using it, updating software etc) doesn't work, and hasn't worked with the two previous replacements either. I'm sure the connectors have been done properly on all of them. I read somewhere that running some system config software is necessary, but is that true? And if so where can I find it please?
    Thanks!
    Jeff G - crwdns2934203:0crwdne2934203:0
    Same problem, the camera does not work. Have you found the solution ??
    Laurent -
    Excellent instructions! 5 stars for the author. Take your time, lay out the screws you remove in a pattern to facilitate reinstallation. From a novice here, think twice before screwing anything back in place. I installed the screen only later to see the antenna rack facing the outside of the computer and not the motherboard. Problem resolved, everything works!
    Aldo Ciccotelli - crwdns2934203:0crwdne2934203:0
    I changed my screen. I am able to boot but the screen is totally black.
    irmb r - crwdns2934203:0crwdne2934203:0
    I would add an extra warning to the last instruction here...
    On my first attempt, the old screen hinges slipped out of the frame quite easily, which fooled me into thinking the new one would slip into place easily. It did not.
    The new screen got stuck, and in the process of trying to get it unstuck, the whole assembly slipped sideways by about an inch, and one of the display ribbon cables got sliced in half. 💀
    My advice: Practice getting the hinges back into place with the old screen. Only attempt the new screen once you've got the hang of what to expect when rotating it into place.
    Peter Gaultney - crwdns2934203:0crwdne2934203:0
    Awesome guide! Thank you. My removal and replacement went smoothly!
    Darrell Wicker - crwdns2934203:0crwdne2934203:0
    Patrick's Plan to attach new screen:
    1. Lay Mac - keyboard DOWN - hinge side toward U on the table.
    2. Pull it toward U till about an inch off the hinge end extends over the table edge.
    3. Using needle nose pliers open the hinges of the screen to just a bit MORE than 90º.
    4. Turn the screen hinge-side UP screen facing AWAY from your belly.
    5. Extend the video connector assembly fully on to the computer.
    5. Fit the hinges - 1 side at a time - into their notches on the computer.
    6. Press them in firmly with your thumbs
    7. Insert and tighten the CENTER screw on BOTH sides.
    8. PIck up the Mac & close it, S L O W L Y.
    VOILA! It's in there. Right...? ;-}
    Now open it up and finish re-assembly.
    以下供参考:
    更换屏幕总成后如果开机无反应,可以拔掉天线板小排线(紧挨着屏幕排线的那根),然后连接充电器后再尝试一下开机,如果能开机就稍微擦拭(吹)一下排线及排线扣,再接好排线开机即可(当拔掉这根排线开机时可能电量显示不足,不用担心)
    Justin Tan - crwdns2934203:0crwdne2934203:0
    Hi guys.
    Is it possible to just remove the glass from the display?
    My display is working fine, but i have some water stains between the glass and the display.
    No need to change everything. but seems like it is not so easy, or?
    All the best from Berlin!
    Tim Ziola - crwdns2934203:0crwdne2934203:0
    Until I read amiller770's comment about, regarding Apple's instructions for reassembly - https://support.apple.com/en-us/100599, I couldn't quite figure out how to get the hinges into the case. As soon as I saw it, it made sense. Thanks.
    Matthew Hey - crwdns2934203:0crwdne2934203:0
    Fantastic manual, really appreciate all the work you guys do.
    Lee Mac Mechanic UK
    David Jones - crwdns2934203:0crwdne2934203:0
    Amazing guide! You guys are always my go-to for repair guides. Replacing the display assembly on the Macbook Air M1 was surprisingly easy. It took me about 30-45 minutes.
    Michael Carannante (Mikey) - crwdns2934203:0crwdne2934203:0
Once you've completed your repair, your laptop may not power back on until connected to power.
crwdns2935229:0161crwdne2935229:0
Carsten Frauenheim
138.497 crwdns2915208:0crwdne2915208:0
crwdns2935297:0379crwdne2935297:0
Staff
crwdns2935297:019.806crwdne2935297:0
crwdns2947412:067crwdne2947412:0
How to make the True Tone working on the screen from another air?
William Kang - crwdns2934203:0crwdne2934203:0
The screen that your replacing should have true tone built in, it is a part of the display.
h_man08 -
Like iPhones does the display need to be programed to allow true tone to work?
Zuhayr Muse - crwdns2934203:0crwdne2934203:0
Just did the replacement! Was a breeze, just be careful not to over tighten any of the screws past a firm twist. Accident broke the head off a 1.5mm screw using a T3 bit. Didn’t affect the plates ability to cover or apply a firm press downwards, but a unfortunate thing nonetheless.
Caleb Stewart - crwdns2934203:0crwdne2934203:0
After Replacing the display, the new display is dim and the F2 does not brighten the screen. Any resolution to this issue?
Already reset NVRAM and PRAM.
Beto Beto - crwdns2934203:0crwdne2934203:0
same issue here. it looks more dim
Boy Named Kelly -
I wonder that things seem to be that easy according to this guide because as you can read here Apple seems to have made it impossible to DIY
Thilobi -
Step 4 and 7 were T4 Torx screws for me.
Thomas Anderson - crwdns2934203:0crwdne2934203:0
Install took about 30 min. and was pretty easy. I didn’t have trouble throughout the process. The adhesive on antenna plate was pretty strong, but with some gentle prying it came free.
shwinston - crwdns2934203:0crwdne2934203:0
I successfully installed the replacement screen, but now my 2.4 Ghz wifi / bluetooth antenna is not working. Any idea which connector cable connects to 2.4 Ghz antenna?
Lars - crwdns2934203:0crwdne2934203:0
I had the same problem. The reason was that I didn't connect the antenna back completely. Redo the step n. 6 in reverse and connect the antenna right (it must click).
Mirek Šiřina -
Done. Works . Biggest chalange was with plugging in back the display cabel connector . Be sure to pre alling the Screen bar with cabel conector , becouse it cannot bend on sides.
Jakub Reginia - crwdns2934203:0crwdne2934203:0
I tried the replacement. Everything works except True Tone as expected. Probably special tool is needed for the True Tone.
Ryan Kojima - crwdns2934203:0crwdne2934203:0
I’ve got the display from an Intel 2018 Air. Can I test it with an M1 Mac? The process and connectors look the same.
Jon - crwdns2934203:0crwdne2934203:0
Did you try this? If so, was it successful?
Lee -
Just tried this - it doesn’t work. M1 MacBook refuses to power on when connected to a display from a 2018 MacBook Air a1932.
Robert Corlett -
Your instructions were amazing and to the T. Thank you so much for everything
willblakleycomputes - crwdns2934203:0crwdne2934203:0
Hi.
Would the display of a MacBook Air early (intel) 2020 work on this MacBook Air late 2020. Seems to be the same specifications.
Marc Machold - crwdns2934203:0crwdne2934203:0
I change my screen but the camera doesn’t work, I checked the hardware’s but MacBook doesn’t have any camera, I tried 3 different screens , all are same. i tried all resets but still not working, any ideas?
Erhan Engin - crwdns2934203:0crwdne2934203:0
hi i have the same Issue do you have a solution?
Philipp Kuhn -
same problem here!
Pomar Filmes -
Same problem here, it seems we need the « system configuration tool » from Apple to make it works.
Laurent -
Hey, I have this same issue. It seems we need some software provided by apple(Only if you buy from their self service website) which i didnt..... Has anyone found a fix?
Jake Wakeman -
I have the same issue, I've tried two OEM screen replacements and now I purchased a genuine Apple M1 2020 screen in perfect working condition. Camera still does not work, but it is recognized in the system report. I've tried all the software fixes, resetting Pram and Nvram, terminal etc. Seems to be a hardware issue. Can I replace the cable for the insight camera?
johnalancovey -
Does this repair cause any feature issues? so, would the webcam not work or truetone not work? Even if i use genuine, donated apple parts?
Thank you!
Jubi Q - crwdns2934203:0crwdne2934203:0
I did encounter these issues with a genuine donated apple part...
Jake Wakeman -
Third-party screens may be missing the fat-L shaped shields and T3 screws flanking the display connector (visible in Step 9), if you bought one somewhere else be sure to transfer this hardware as well.
cressandy - crwdns2934203:0crwdne2934203:0
Certain parts like displays, cameras, and ambient light sensors have calibration values that are customized to each individual part during manufacturing. Transferring these values ensures maximum performance and quality after a repair.
A System Configuration step may be required at the end of your repair. System Configuration is a postrepair software tool that completes the repair for genuine Apple parts. Running System Configuration has a number of purposes that vary based on the part replaced.
Tony Fresquez - crwdns2934203:0crwdne2934203:0
Where do I get this software? System Configuration ? After three displays, including one Genuine Apple Display taken from a working MBA, with no defects, I can't get the camera to work. It is recognized by the system report
johnalancovey -
I'd replaced replaced the display on a MBP 2012 before, so I didn't anticipate any problems replacing the display on my A2337. Everything seemed to go smoothly, but when I booted up (with power cord attached), I didn't get more than a faint glow from the screen. I tried all the usual, but still no luck. I went back and made sure everything was seated properly but I got the same results. So, I reinstalled my cracked screen, which worked perfectly, outside of the cracks. You think I can assume the part was defective? I bought it from eBay, and it at least claimed to be OEM.
Pia Vastatrix - crwdns2934203:0crwdne2934203:0
Did you find a solution?
Stefan Schötz -
Is there a way to tighten the hinge? I would like to have my display tighter. It always flips back when I pick up my MacBook. That's not the case for my girlfriends MacBook which is the exact same model.
Marcel Braun - crwdns2934203:0crwdne2934203:0
It disappeared after replacing the display of macbookair m1! I put it back, but it doesn't work! However, I know I can go into recovery mode and DFU mode, but I get an error and can't restore! What should I do?
河田かずま - crwdns2934203:0crwdne2934203:0
All went great, very detailled manual. Unfortunately the new display doesn't work. The backlight is on but it shows no graphics. I managed to get the mac working with an external display. MacOS shows the display but nothing happens. Connectors are all doublechecked of course. Any ideas?
Stefan Schötz - crwdns2934203:0crwdne2934203:0
Additional info: It is a M1-Macbook Air A2337.
Stefan Schötz -
Where did you buy the display module, please?
Sebastian Slania -
すみません、macbookair m1の交換用のスクリーンをインストールする方法を教えてください!
Apple only sells the display itself with our the clamshell. That makes the repair so much more complicated and I am sure they know it. Any ideas how to get the entire display module including the clamshell?
Sebastian Slania - crwdns2934203:0crwdne2934203:0
Sebastian,
The display part Apple sells through Self Service Repair is the entire assembly/module, including the panel, aluminum shell, camera, hinges, etc. The display we sell is also the entire display assembly. Hope this helps—happy fixing!
I replac the display the on MacBook Air but the display is not turning on I do not no what to do??
info - crwdns2934203:0crwdne2934203:0
This tutorial has been a life saver! Thank y’all so much!
Only snag I came across was on installing the replacement screen as the screen is easily damaged when getting the hinges to connect. So it’s important to be super careful at that part!
Briana - crwdns2934203:0crwdne2934203:0
This was so helpful. Thank you,
Used the iFix kit to replace a cracked screen on my daughter’s MacBook Air. Has been working without any issues. Now today, went to power it on, the screen is black. Powered on and off. Still not getting anything on the screen
Rob - crwdns2934203:0crwdne2934203:0
It worked pretty well, only removing the antenna was quite hard.
When I turned on the device the battery was not recognized so I had to re-connect the battery and then it worked.
Fabio L - crwdns2934203:0crwdne2934203:0
PLEASE HELP:
I followed this guide and although the antenna bar was kind of tough to remove, everything seemed to work fine. I replaced the screen and reassembled my MacBook Air. Everything works fine. BUT for the wifi. It works but signal is ridiculously low. Unless my M1 is within 3m and in direct sight of my router, wifi signal is gone or at 1 bar (out of 3). I have reopened the M1 and checked all the connectors: they all seem fine. Any suggestions?
The steps were clear and to the point. Great job on write up. Had no issues with the screen replacement and the unit fired right up after. The reconnect of the antenna was the scariest part just did not feel that the reconnect went well. You might do a follow up and just focus on that step on the reassemble.
markanderson - crwdns2934203:0crwdne2934203:0
Mike, that step was missing reassembly information. I added it in. Thanks for the callout, and I'm glad your repair went well!
does anybody knows if a 2021/2022 MacBook air M1 display is compatible? apparently Intel ones arent as they refuse to boot
Leo - crwdns2934203:0crwdne2934203:0
Leo, the Intel variant Air would be the early 2020 model. The late 2020 M1 model is different. And 2022 M2 displays are not compatible. Hope this helps!
Guide worked well, took about an hour. Thought I lost one of the tiny plate screws and searched forever then realized the WiFi cable cover is only one screw.
Because the antenna is difficult to start to pry up, suggest you do what I did and unscrew the hinge screw that is just under the antenna as this works to break the seal on the adhesive. Then of course screw it back in and pry/insert with your plastic tool to detach the rest of the adhesive.
Take your time and if you are old like me get a bright light and a magnifying glass/headset. Helped getting the little screws in and making sure the connectors for the antenna, display and power were in properly.
Joseph Collins - crwdns2934203:0crwdne2934203:0
MacBook A2337 Air M1 2020 l écran est il le même que le macbook A1932
Gedfr - crwdns2934203:0crwdne2934203:0
non, ça ne correspond pas
Thilobi -
Remember to put the inner screen screws before screwing the antenna in....
Dave Motion - crwdns2934203:0crwdne2934203:0
Bonjour quand l’écran est complètement exploser vaut-il mieux changer que l’écran ou l’ensemble capot et écran compris , dans ce exemple vous changer capot et écran , es ce qu’il y a un tutoriel avec l’ensemble de la procédure
Par avance merci
tout est collé ensemble et n'est pas recommandé
Thilobi -
This guide worked great. I first tried an Ebay-sourced part that claimed to be genuine, but it didn't even turn on. I had better success with a non-OEM part from Amazon that works really well. The only things that don't work are True-Tone and the brightness defaults to 50% when I open the lid. Everything else is pretty good!
Rodingo13 - crwdns2934203:0crwdne2934203:0
looks like it's a little bit of a lottery, some made it, some not. In this iFixit-Thread they say you definitely need a screen from Apple's Self Service Repair to make it work, but some users here seem to made it with parts e.g. from Amazon.
Does anybody have details to this issue?
Thilobi - crwdns2934203:0crwdne2934203:0
how to dry water spots in the screen?
NIKOLAOS ARIFIN - crwdns2934203:0crwdne2934203:0
There’s a small clicking noise now when I close the lid that is there when the lid is about 90% closed - is that from the antenna bar being bent a bit perhaps?
soccerjoshj07 - crwdns2934203:0crwdne2934203:0
Could be, but may also be from another minor misalignment. I recommend loosening the six hinge screws a bit, see if you can find a place where it doesn't click, then re-tighten them. While you're in there, make sure everything's seated and flush. Best of luck!
remember to remove the extra cable connector covers from either side of the antenna board if you don't have them on the new display - easier to do this before you remove the antenna bar screws in step 10
Richard - crwdns2934203:0crwdne2934203:0
I could kiss you (no tongues). Thank you so much. Didn't take as long as I thought it would, my god some of those screws are tiny, I only managed due to a magnetiser.
Again. thank you so much.
Keith Smith - crwdns2934203:0crwdne2934203:0
How do I find a screen that fits my machine?
Brandon Oxendine - crwdns2934203:0crwdne2934203:0
How am I supposed to disable my Mac's "Auto Boot" feature if my screen is broken?
crwdns2936751:024crwdne2936751:0 285
crwdns2936753:07crwdne2936753:0 1,792
crwdns2936753:030crwdne2936753:0 8,285
crwdns2942667:0crwdne2942667:0 322,161
