Use this guide to remove or replace the right speaker in an Early 2020 MacBook Air.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$16.96
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
Pull the adhesive strip until it's freed from under the speaker.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Remove the right speaker.
