Use this guide to replace the fan in an Early 2020 MacBook Air.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
When reassembling, the “snaps” are in the middle of the laptop (from top to bottom), and just to the left and right of center. I assumed it was near the hinge so it took a bit for me to hear the snaps.
Laurie, the two clips are outlined in the third photo of step two. Hope this helps—happy fixing!
What tool kit should I use for this?
the second picture is m1 air right?
the antenna cable position does not match later picture
Peel back the tape covering the battery connector enough to reveal the connector underneath.
This image is incorrect correct for the A2179 EMC 3302 model, also doesn’t match the next image in this guide
There is other guide for the model you reffer to, I was using that one until i realize it was different, this is the one you are looking for: MacBook Air 13" Retina Late 2020 (M1)
I initially thought the image was incorrect, but I was just looking for the connector in the wrong place. This picture IS correct for the A2179 EMC 3302. Note that the connector is on the left side of the heat sink (the black thing with parallel ridges in the picture and on the computer), and the connector wires gather together towards the left the side of the computer, not the back. Note that "left side" assumes the Air is upside-down, with the hinge on the side farthest away from you (I'm not doing the "right speaker is on the left side because it's upside-down" thing that iFixit does in step 5).
How do you find out if you have a Retina Late or Retina Early model?
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
It’s stuck can’t get it out
Me too. It’s really stuck in there. Not sure if I should attempt the usb c port replacement if I can’t disconnect the battery.
Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
Remove the audio board connector cover.
Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
Use a T4 Torx driver to remove the three screws securing the audio board:
Two 4.3 mm screws
One 2.4 mm screw
I have an Early 2020 MacBook Air in front of me and the 2.4 mm screw is a T3 Torx (not a T4)
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to peel back the black tape covering the fan cable connector.
Use the pointed end of a spudger to lift up the small locking flap on the fan cable's ZIF connector.
Slide the fan cable out of its connector.
Slide an opening pick underneath the audio board cable to separate it from the fan.
Use a T4 Torx driver to remove the three 2.7 mm screws securing the fan.
In my case, the screw on the left was a T5
Be careful not to over tighten these screws! They striped out extra easily.
Lift the fan out of the case to remove it.
crwdns2935229:05crwdne2935229:0
Thank you very much. This helped me a lot when my fan started making buzzing noise an$ had the change it.
P5 is also a PL4 (so confusing) - i like the wiha 26764 thanks to @mayer for this post. P5 pentalobe and 1.2 pentalobe screwdriver
greg - crwdns2934203:0crwdne2934203:0
