Use this guide to replace the display in an Early 2020 MacBook Air.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$16.96
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
Remove the antenna cable cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to grip the antenna connector close to its base.
Pull straight up to disconnect the cable.
Repeat for the second antenna cable.
Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
Remove the display cable connector cover.
Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
Use a T5 Torx driver to remove the six screws securing the antenna bar:
Four 7.4 mm screws
Two 4.5 mm screws
Insert the pointed end of a spudger into the gap between the antenna bar and display hinge.
Pivot the spudger against the hinge to pry up the end of the antenna bar.
Repeat for the other end of the antenna bar.
Use your fingers to pry the antenna bar straight up and away from the case.
Thread the antenna board through the opening in the middle of the antenna bar.
Remove the antenna bar.
Use a T8 Torx driver to remove the three 4.9 mm screws from each hinge (six screws total).
With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
Lift the MacBook and carefully begin to close the display until it's at a ~90 degree angle with the upper case.
Keeping the display at a 90 degree angle with the case, move the display straight down while holding the case still, so that the hinges slide out the bottom of the case.
Remove the display.
crwdns2935229:050crwdne2935229:0
crwdns2947412:013crwdne2947412:0
Thank you so much for this awesome walkthrough! I can’t believe how much I saved doing this myself. Works beautifully! If I could only suggest a more comprehensive “reassembly” page. There are a couple of missteps I made (eg. trying to install the antenna bar and accidentally leaving the display cable connector under it) that would have helped. In any event, thank you so much!
Thanks for the tip! I’ve added a reminder to that step.
when starting the process of installation, make sure that at least the inside hinge screw is installed and mostly tightened. once the antenna is installed, there is almost no room for that screw to be inserted without a tight scrape against the end of the antenna. a very tight fit. i sometimes only install one hinge screw, usually the center ones, and then align the lid before adding the others and tightening everything up. in this case, would save you some concern to address this beforehand.
Is that instruction can be used for Macbookpro 2010 with touch bar?
Definitely not. Also, there is no such thing, perhaps you meant 2020? Also no.
