Use this guide to replace a faulty logic board in your MacBook Air 13" early 2018.
Be sure to apply a new layer of thermal paste before reinstalling your heat sink on your new logic board.
   crwdns2935267:0crwdne2935267:0P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99-
            Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
            Two 9 mm screws
            Eight 2.6 mm screws
            Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
            Remove the lower case and set it aside.
            Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
            Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
            Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
            While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
            Remove the I/O board cable.
            Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
            Peel the rubber gasket off the adhesive on the top of the fan.
            Remove the following three screws securing the fan to the upper case:
            One 3.6 mm T5 Torx screw
            One 2.7 mm T5 Torx screw
            One 3.6 mm T5 Torx screw with a short head
            Lift the fan from the I/O board side and pull it free from the upper case.
            Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
            Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
            Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
            Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
            Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
            Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
            Lift the I/O board from the logic board side and pull it free from the upper case.
            Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
            Remove the following five screws securing the battery to the upper case:
            Three 6.3 mm T5 Torx screws
            Two 2.4 mm T5 Torx screws
            Lift the battery from its edge nearest the logic board and remove it from the upper case.
            Grab the plastic pull tab secured to the display data cable lock and rotate it towards the top side of the computer.
            Pull the display data cable connector straight away from its socket.
            Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
            Disconnect the camera cable connector with the tip of a spudger.
            Pull the camera cable parallel to the face of the I/O board toward the front edge of the Air to disconnect it from its socket.
            Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
            Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
            Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
            Use your spudger to gently pull the keyboard backlight ribbon cable out of its socket.
            Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
            Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
            Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
            Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
            Slide the flat end of a spudger under the right speaker from the end nearest the hinge to the front edge of the Air to loosen the adhesive.
            Remove the right speaker from the upper case.
            Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
            Keep loose cables clear of the board so they aren't caught under it.
            Make sure the antenna cables are inserted into their respective notches, as highlighted in the second picture.
            Remove the single 2.85 mm T5 Torx screw securing the SSD to the logic board.
            Pull the drive straight out of its socket and remove it from the logic board.
            Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth board to the logic board.
            Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
            Remove the AirPort/Bluetooth board from the logic board.
            Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
            Remove the heat sink from the logic board.
            Make sure the antenna cables are inserted into their respective notches on the logic board, as highlighted in the last picture.
crwdns2935229:012crwdne2935229:0
Can you use an 2017 logic board onto a MacBook Air 2014 “body” (13”)? Airs from 2013 to 2017 seems to be aboud the same CPU and all others parts are the sam also.
Do you have any video of this case working?
Great guide, worked like a charm. I just swapped out the logic board from a cosmetically destroyed (case and screen only) MacBook Air 2017 i7, into a cosmetically perfect i5 model that has logic board issues which I purchased on eBay. Works perfectly. Thank you!
