MacBook Air 13" Early 2017 SSD Upgrade to NVMe
    • MacBook Air Late 2010 - Working - High Sierra, Catalina, M2 Samsung Evo 860, Adapter
    • MacBook Air 2011 - Working - High Sierra, M.2 Transcend MTS830S SATA III, Long Adapter.
    • MacBook Air 2012 - Working - Catalina, M.2 Transcend MTS830S SATA III, Long Adapter.
    • MacBook Air 2013 - Unknown
    • MacBook Air 2014 - WD_black 500 + Sintech adapter, running MacOS Big Sur
    • MacBook Air Early 2015 - WORKING- Mojave 10.14.3 to Big Sur 11.0.1- Crucial P1 SSD NVME, Adapter.
    • MacBook Air 2017 - WORKING - High Sierra, Catalina and Big Sur, Monterey - Transcend MTE250S PCIe 4.0 4x NVMe, Long Adapter + Kapton Tape.
    • MacBook Air 2018 and forward - will not work, No removable drive
  1. MacBook Air 13" Early 2017 SSD Upgrade to NVMe, Lower Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 SSD Upgrade to NVMe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 SSD Upgrade to NVMe, Solid-State Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  4. MacBook Air 13" Early 2017 SSD Upgrade to NVMe: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2017 SSD Upgrade to NVMe: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  5. MacBook Air 13" Early 2017 SSD Upgrade to NVMe, SSD - Alternate option using M.2 NVMe SSD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2017 SSD Upgrade to NVMe, SSD - Alternate option using M.2 NVMe SSD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully insert the new SSD into the adapter, using the length of old drive as a reference for when the SSD is fully in the adapter. The lengths should be the same.
    • Insert the SSD and the adapter into the Socket, pushing inward in a straight fashion.
    • NVMe Drives can cause kernel panics due to sleep /hibernation issues. This can be turned off with the following command.
    • From a Terminal, use the following command to disable hibernation: ----"sudo pmset -a hibernatemode 0" ---- If you later want to enable hibernation, use: "sudo pmset -a hibernatemode 3"
crwdns2935229:039crwdne2935229:0
Dan
crwdns2935283:002/18/19crwdne2935283:0
4.538 crwdns2915208:0crwdne2915208:0
crwdns2947412:064crwdne2947412:0
I have a Macbook air 2017 1466this model https://support.apple.com/kb/SP753?local...
macOS Mojave ver 10.14.6. will your manual work?
l.cichon85 - crwdns2934203:0crwdne2934203:0
Yes, this Manual will work for your Device.
Greets - Maik
Maikp735KR -
Thanks!
A little observation: the time estimate for the operation is 5 hours, is an error?
Blacy - crwdns2934203:0crwdne2934203:0
5 hours will include the time needed to install OSX on the new drive. Swapping the drive is extremely fast
Dan -
Hi!.. Does anyone knows if the crucial SSD will work with the Macbook Air 13” 2017?
Thanks!
Francisco Rojas - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 106
crwdns2936753:030crwdne2936753:0 570
crwdns2942667:0crwdne2942667:0 126,966
