MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement
  1. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
crwdns2935229:09crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
215,560 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
Perfect instructions,
Worked first time, without any issues!
THANK YOU :-)
Tahir Khan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 105
crwdns2936753:030crwdne2936753:0 357
crwdns2942667:0crwdne2942667:0 13,115
