MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement
  1. MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement, Battery Connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
crwdns2935229:017crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
472.738 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:020.934crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Hi! I did this as the bluetooth was not working on my macbook air (after water damage). Once I replaced it, instead of a "bluetooth not available" dialogue, Bluetooth options now do not appear in the System Preferences window, and in the system report, it just says "no information available".
Is this a connection issue, did I get the wrong card, or did the water damage actually destroy the antennae? Wifi works fine both before and after replacing the card.
Campbell Robinson - crwdns2934203:0crwdne2934203:0
Hi,
i opened up my Mac and cleaned it after water because it was running slow and the fan was going crazy. IT worked and I hadn’t no notebook issues when I ran apple diagnostics but now I can’t see all my wifi networks or even connect to my phone wireless hotspot And it keeps saying password invalid wen it’s always right!
The wifi shows the same networks like 3 of them but there use to be at least 30 as I live in an apartment block. Is this a airport problem or antenna??
Peeppeep - crwdns2934203:0crwdne2934203:0
I cannot get the airport card antenna wires to connect to the new airport card. Is there some trick to getting them to snap in place?
rhood2796 - crwdns2934203:0crwdne2934203:0
for connecting antenna wires to airport card. You need to hold in place with tweazers then push down with finger or blunt spudger. be careful as you dont want to damage to connector if not placed perfectly in place. ive damaged one before so if it doesnt feel right dont apply to much pressure. reseat and try again
Jay - crwdns2934203:0crwdne2934203:0
Hi Sam, Evan, all,
I have some difficult technical questions I’d really like to ask I do not need you to condone regarding some BGA/soldering repairs. I’d love to ask you some spec questions. You’re well versed in Apple tech and I a computing-array guy. I would love a message back wherever you’re comfortable. I am building up to the intense process of motherboard creation & design with have no illusions that this is easy (I have done my research). I’m going to desolder the RAM here & it I have plenty of parts to break now so <20% chance is fine. My current project requires honing skills. When I get to the higher echelons/PRICEY equipment I need a proficient competency in this basic stuff as foundation.
Email is ibrad215@gmail.com I doubt you want a public answer on a guide for anyone with Google, but I could really use some help making a few decisions I won’t hold against you if they fail. Call it computer science and not faultless repair, & a chance to learn I will gladly share w/you as research!
@sam @evan
ibrad215 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 162
crwdns2942667:0crwdne2942667:0 35,318
